Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-08-2013, 15:24 | #2 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | this way.................. Hard Reset Micromax Canvas HD A116 Switch Off your phone. Press and hold Power button together with ‘volume +’ and ‘volume –’ buttons on the side of phone until you get two options. Now, press the ‘volume +’ button to enter into the recovery mode. This will make a Android icon appears on screen, press power button. This will get you the menu options, use the volume up and down button to choose the option. To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds. Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage. Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. |
03-08-2013, 15:49 | #3 (permalink) |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Use magic search button bro already posted in stikcy thread How to hard Reset Micromax A116 Canvas HD br, azam |
06-05-2013, 09:53 | #4 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: india
Member: 1701545 Status: Offline Thanks Meter: 100 | this key work for me Quote:
06-07-2013, 12:26 | #6 (permalink) | |
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
http://forum.gsmhosting.com/vbb/9231329-post14.html Br, azam | |
07-06-2013, 12:19 | #7 (permalink) |
Freak Poster Join Date: Mar 2005 Location: sirsa Age: 56
Member: 123740 Status: Offline Sonork: [email protected] Thanks Meter: 28 | not working for me all procedures |
10-09-2013, 12:10 | #10 (permalink) |
Junior Member Join Date: Jun 2009 Location: india Age: 36
Member: 1063204 Status: Offline Sonork: mujeebbridco Thanks Meter: 0 | Hard Reset Micromax Canvas HD A116 Switch Off your phone. Press and hold Power button together with ‘volume +’ and ‘volume –’ buttons on the side of phone until you get two options. Now, press the ‘volume +’ button to enter into the recovery mode. This will make a Android icon appears on screen, press power button. This will get you the menu options, use the volume up and down button to choose the option. To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds. Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage. Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. 100% working for me thx |
02-01-2014, 09:53 | #13 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 659890 Status: Offline Thanks Meter: 263 | Quote:
100% working method to hard reset the device. | |
