Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 04-07-2013, 12:46   #16 (permalink)
Member: 1912091
no ...its not cming...as im new...pls post detailed step by step procedure here pls....reply as soon as possible...shld i switch it on n den connect or shld i boot it...actually teied everything
Old 04-07-2013, 18:41   #17 (permalink)
Member: 1912091
waiting for a reply...pls reply
Old 04-07-2013, 20:33   #18 (permalink)
Member: 564436
Thanks Meter: 132
simple step1 goto fast boot mode and connect phone to PC run unlock software
press 8 number in PC key Bord done
its work for me good
Old 04-09-2013, 07:49   #19 (permalink)
Member: 185776
Thanks Meter: 73
How to go Fast boot mode?
Old 04-09-2013, 08:03   #20 (permalink)
unlockers555's Avatar
Member: 547368
Thanks Meter: 254
volume - and power on
Old 04-09-2013, 10:18   #21 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
as i see this funbook with my hand and i flashed it with ur help
and it not have volume button
and its only flash is option
home key press then insert cable then after few sec press and releise power button till software acept for flash
Old 04-09-2013, 10:58   #22 (permalink)
Member: 1912091
No guys,im able to enter boot mode,but wen i press ne option nthngs hpng
Old 04-09-2013, 11:36   #23 (permalink)
Member: 547368
Thanks Meter: 254
try to press home button and insert usb cable (no press power key)
Old 04-09-2013, 11:39   #24 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
for this modle need toggle on/off key
Old 04-19-2013, 09:10   #25 (permalink)
Member: 765926
Thanks Meter: 57
Thumbs down Cant fastboot micromax infinity tab
None of the methods is working. pressing home & toggling on/off does make the pc detect a new hardware, but after successfull unstallation the adb tool still does not work.
Remember, the issue is forgotten pattern lock
Old 04-19-2013, 09:20   #26 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
yes i say before also that only flashing is option for pattern unlock not hard reset
Old 04-19-2013, 09:43   #27 (permalink)
Member: 765926
Thanks Meter: 57
no solution
But how can one root this tab, when you can't even select the usb debugging mode. If every android phone can be started in a fastboot option and can be reset by wiping the user data, why can't this one.
i am sure there must be some way out. But still unknown.
Old 05-29-2013, 15:51   #28 (permalink)
Member: 1949657
intex ibuddy connect tablet pattern unlock‏
My tab is asking for gmail user name and password which I have not registered. I download this tools but I is not getting run
ok let's try to solw your problem
download this tool
connect your phone
press 5 for normal wipe
and prees 8 for fastboot wipe then enter
Old 06-30-2013, 11:12   #29 (permalink)
Javed ajmeri's Avatar
Member: 424082
Thanks Meter: 128
Arrow
open live suite
press start then
Continuesly press side 'HOME' key, insert cable then toggle ON/OFF key, SW will start
Old 08-24-2013, 04:42   #30 (permalink)
Member: 2009420
how to unlock the petern for micromax infinity p275.
now it shows the screen only type your mail id and passwor.....Tried a a lot but no result. Please help me ....i am a student
Page generated in 0.26403 seconds with 8 queries
