Micromax General Micromax phones discussion, firmwares, solution, root, help |
08-31-2015, 14:27 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2015 Location: faridabad(delhi) Age: 33
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | [How to] Repair IMEI Invalid | NV RAM Warning | Micromax Unite 2 REQUIREMENTS One week after i brought my phone, I accidently formatted my device using sp flash tools and lost the IMEI/NVRAM. It has been a real pain for me to repair it because i was new to an mtk device. Finally figured out how to repair by doing many search. So I made this thread to share the working methods to help those people who are suffering from invalid IMEI So let's start. [IMG]****************************/convkey/4671/nlhpf0o6xnl9r5w6g.jpg[/IMG] Always remember "Prevention is better than cure". If you are planning to flash a custom rom, First of all Backup your IMEI. Don't Trust that a custom ROM flash will not delete your IMEI number. because odds are it will. It's important to store your backup to external SD because some ROM flashing techniques will erase your internal SD. so the best way to keep your IMEI number is to take my advise and make a backup. Some Video tutorials will be added soon DISCLAIMER: Do not do try any of these methods unless your IMEI has been lost! Doing so may permanently corrupt your imei partition. IMEI Backup & Restore Methods: 1. Mobile Uncle Tools: 1. Open the App, 2. Select IMEI BACKUP RESTORE (MTK) 3. Choose BACK UP TO SDCARD (MTK) 4. Reboot >> (to restore, choose restore from sd card) 2. MTK Droid Tools [PC Required]: 1. Switch on the phone and connect it to pc. 2. Go to settings->about phone. 3. Tap build number for 7 times. 4. Go back and enter developers options, and check usb debugging on. 5. Start MTK Driod Tools and click root. grant root permission in phone. 6. Click IMEI/NVRAM and click backup or restore as required. >> (to restore, choose the backup file from nvram backup folder) Temporary IMEI Restore (without Backup): (These are Temporary Methods, so you need to do this every time you upgrade Firmware, install a new rom, or doing a factory reset.) 1. Chamelephon 1. Install Chamelephon.apk 2. Open App 3. Type both IMEI Numbers 4. Click "Apply new IMEIs" 5. Reboot Video Tutorial 2. MTK Droid Tools [PC, ADB Drivers Required] 1. Enable USB debugging 2. Open MTK Droid tools in PC 3. Allow USB debugging in phone if asked 4. Click ROOT button in MTK droid tools 5. Click Yes and Grant/Authorize root permission in phone 6. Click IMEI/NVRAM option in MTK droid tools 7. Type both IMEI numbers 8. Select "Replace IMEI" 9. Click OK 10. Reboot! Video Tutorial 2. NVRAM Wifi Error 1. Download "NVRAM Wifi Fix.zip" 2. Enter Recovery 3. Install the zip 4. Reboot Permanent IMEI Restore(without Backup): 1. Maui META 3G Tool (CDC drivers Required) 1. Install "Maui META 3G Tool" on your PC 2. Open it. 3. Click "Options ↦ Connect Smart phone into META mode" 4. Click on Reconnect button 5. Switch off your phone 6. Connect via USB Cable 7. Change "Get Version" to "IMEI Download" 8. Click "Change NVRAM Database file" 9. Download & extract "NV Ram Database Files.rar" 10. Select "BPLGUInfoCustomAppSrcP_MT6582_S00_MOLY_WR8_W1315_ MD_WG_MP_V5_1_wg_n" 11. Type both IMEI numbers 12. Click "Download to flash" 13. Click "Upload from flash" 14. Close the IMEI Download Tab 15. Disconnect 16. Switch on the phone. 2. IMEI&SN Writer Didn't tried this method. Hope this too will work! 1. Flashing NVRAM.bin (Recommended for Lolipop Roms ) 1. Install SP flash tool 2. Load Scatter file 4. Now press download 5. Connect your phone without battery 6. Insert battery & turn on your device when you see the green tick. DOWNLOADS Mobile Uncle Tools - Click Here! MTK Droid Tools - Click here! Chamelephon App - Click Here! NVRAM Wifi Fix.zip - Click Here! Maui META 3G Tool -Click Here! NV Ram Database Files.rar - Click Here! IMEI&SN Writer - Click Here! MT6582_Android_scatter.txt - Click Here! NVRam.bin - Click Here! Bro here is your file click and download here one click download link if you like my post just press onlybutton _________________ B.R Abhay_Rana_Singh!!!! |
The Following 4 Users Say Thank You to abhayranasingh For This Useful Post: |
