Micromax General Micromax phones discussion, firmwares, solution, root, help |
07-16-2013, 08:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: coimbatore
Member: 653676 Status: Offline Thanks Meter: 301 | Micrmax A92 Hard Reset Procedure Try to Hard reset the Phone But no Procedure in the Net... But i found that will share with you 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys 6).For Select Press the Home key 7).If Its failure Press the Power key Ones and then Select the ''Factory Reset'' menu ..Then Press ''Menu key and Home Key two times'' .....If any Other Problem Please Reply |
09-13-2013, 14:41 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Tiruvannamalai,Tamil Nadu
Member: 450110 Status: Offline Thanks Meter: 187 | Micromax a92 hard reset 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu.. 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys.. 6).Select wipe data factory, 7).Press the Home and option key at the same time.. Now enjoy.. By Jai... |
The Following 7 Users Say Thank You to jaijee For This Useful Post: |
10-18-2013, 13:26 | #4 (permalink) |
Junior Member Join Date: Apr 2012 Location: DHAKALIAPARA DDP CENTEER ASSAM Age: 32
Member: 1749487 Status: Offline Thanks Meter: 4 | Hi Guys to day I Got a Micrmax A92--Canvas with Google Lock... Try to Hard reset the Phone But no Procedure in the Net... But i found that will share with you 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys 6).For Select Press the Home key 7).If Its failure Press the Power key Ones and then Select the ''Factory Reset'' menu ..Then Press ''Menu key and Home Key two times'' |
The Following 4 Users Say Thank You to raju islam For This Useful Post: |
05-22-2014, 06:33 | #8 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | all solution fake...............1000% ok see here tested you tub... https://www.youtube.com/watch?v=MEjXRhUjxkg 1.) Press Volume+ and Volume- with Power Key (same time presss both key) 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu 5).one click pwr key..and wipe data reset option with vol -up ,down buttun 6).For Select Press the Home key Last edited by ashish800; 05-22-2014 at 06:42. |
The Following User Says Thank You to ashish800 For This Useful Post: |
06-14-2014, 07:28 | #11 (permalink) | |
Junior Member Join Date: Nov 2009
Member: 1155149 Status: Offline Thanks Meter: 3 | Quote:
07-31-2014, 09:56 | #12 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Quote:
Yes Green Color Written Direction Working Tips. Tested By Me Bro:- Palash Ahammad | |
09-13-2014, 14:46 | #13 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: MUMBAI INDIA Age: 35
Member: 697969 Status: Offline Thanks Meter: 8 | Quote:
11-06-2014, 16:53 | #15 (permalink) |
Insane Poster Join Date: Jan 2010 Location: port blair Age: 43
Member: 1215464 Status: Offline Thanks Meter: 3 | Talking Micromax a92 hard reset 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu.. 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys.. 6).Select wipe data factory, 7).Press the Home and option key at the same time.. Now enjoy.. its working 100 |
