Micrmax A92 Hard Reset Procedure Hi Guys to day I Got a Micrmax A92--Canvas with Google Lock... Try to Hard reset the Phone But no Procedure in the Net... But i found that will share with you 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys 6).For Select Press the Home key 7).If Its failure Press the Power key Ones and then Select the ''Factory Reset'' menu ..Then Press ''Menu key and Home Key two times'' ;) .....If any Other Problem Please Reply |
bad idea this form not work |
Micromax a92 hard reset 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu.. 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys.. 6).Select wipe data factory, 7).Press the Home and option key at the same time.. Now enjoy.. By Jai... |
Hi Guys to day I Got a Micrmax A92--Canvas with Google Lock... Try to Hard reset the Phone But no Procedure in the Net... But i found that will share with you 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys 6).For Select Press the Home key 7).If Its failure Press the Power key Ones and then Select the ''Factory Reset'' menu ..Then Press ''Menu key and Home Key two times'' |
Yes It works now. I faced the same issues and the solution provided by Raju worked for me. Thanx a ton... |
thanks its working for me |
all solution fake...............1000% ok see here tested you tub... https://www.youtube.com/watch?v=MEjXRhUjxkg 1.) Press Volume+ and Volume- with Power Key (same time presss both key) 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu 5).one click pwr key..and wipe data reset option with vol -up ,down buttun 6).For Select Press the Home key |
its working for me thank u |
micromax a92 working tested thkssssssssssssssssssssssss |
Yes Green Color Written Direction Working Tips. Tested By Me Bro:- Palash Ahammad |
its working 1000000000000% |
Talking Micromax a92 hard reset 1.) Press Volume+ and Volume- with Power Key 2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory ) 3).Now Press Volume up key .. 4).You Got the Recovery Menu.. 5).Drag down and Up the Menu with the Using of Volume Up and Down Keys.. 6).Select wipe data factory, 7).Press the Home and option key at the same time.. Now enjoy.. its working 100 |
