Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 07-16-2013, 08:46   #1 (permalink)
Member: 653676
Thanks Meter: 252
Talking Micrmax A92 Hard Reset Procedure
Hi Guys to day I Got a Micrmax A92--Canvas with Google Lock...
Try to Hard reset the Phone But no Procedure in the Net...
But i found that will share with you
1.) Press Volume+ and Volume- with Power Key
2.) The Phone Says two Menus (.Press Volume Up for Recovery, or Press Volume Down for Factory )
3).Now Press Volume up key ..
4).You Got the Recovery Menu
5).Drag down and Up the Menu with the Using of Volume Up and Down Keys
6).For Select Press the Home key
7).If Its failure Press the Power key Ones and then Select the ''Factory Reset'' menu ..Then Press ''Menu key and Home Key two times''
.....If any Other Problem Please Reply
Old 09-13-2013, 10:39   #2 (permalink)
Member: 389645
bad idea this form not work
Old 09-13-2013, 14:41   #3 (permalink)
jaijee's Avatar
Member: 450110
Thanks Meter: 185
Talking Micromax a92 hard reset
4).You Got the Recovery Menu..
5).Drag down and Up the Menu with the Using of Volume Up and Down Keys..
6).Select wipe data factory,
7).Press the Home and option key at the same time.. Now enjoy..
By Jai...
The Following 7 Users Say Thank You to jaijee For This Useful Post:
Old 10-18-2013, 13:26   #4 (permalink)
Member: 1749487
Thanks Meter: 4
The Following 4 Users Say Thank You to raju islam For This Useful Post:
Old 02-26-2014, 11:20   #5 (permalink)
Member: 2115925
Yes It works now. I faced the same issues and the solution provided by Raju worked for me. Thanx a ton...
Old 03-30-2014, 14:39   #6 (permalink)
yogesha123's Avatar
Member: 905341
Thanks Meter: 63
thanks its working for me
Old 04-13-2014, 11:44   #7 (permalink)
Member: 715924
Sonork: 100.1662616
Thanks Meter: 83
Old 05-22-2014, 06:33   #8 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 565
all solution fake...............1000% ok
see here tested you tub...
https://www.youtube.com/watch?v=MEjXRhUjxkg
1.) Press Volume+ and Volume- with Power Key (same time presss both key)
5).one click pwr key..and wipe data reset option with vol -up ,down buttun
The Following User Says Thank You to ashish800 For This Useful Post:
Old 05-27-2014, 17:08   #9 (permalink)
Member: 439620
Thanks Meter: 23
its working for me thank u
Old 06-13-2014, 10:32   #10 (permalink)
AFZALHASMI's Avatar
Member: 304342
Thanks Meter: 20
micromax a92
working tested thkssssssssssssssssssssssss
Old 06-14-2014, 07:28   #11 (permalink)
Member: 1155149
Thanks Meter: 3
very good solution brother,good working.............& thanks
Old 07-31-2014, 09:56   #12 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 8,715
Yes Green Color Written Direction Working Tips.
Tested By Me
Bro:- Palash Ahammad
Old 09-13-2014, 14:46   #13 (permalink)
Member: 697969
Thanks Meter: 8
By Jai...
Yesw this is the right way.thanks
Old 11-06-2014, 05:12   #14 (permalink)
Member: 1480905
Thanks Meter: 14
its working 1000000000000%
Old 11-06-2014, 15:53   #15 (permalink)
Member: 1215464
Thanks Meter: 3
its working 100
Page generated in 0.37549 seconds with 7 queries
