Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 10-28-2014, 14:22   #1 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 617
micromax a065 dead recover done
BR,
The Following User Says Thank You to ashish800 For This Useful Post:
Old 11-06-2014, 14:22   #2 (permalink)
Crazy Poster
Member: 698877
Thanks Meter: 10
a065 micromax flash file needed
pls share micromax a065 tested ok flash file
thanx
Old 11-06-2014, 14:25   #3 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
thanx
on support hare is
Welcome to the ./downloads/ folder of GsmHosting support area
Old 08-01-2015, 12:15   #4 (permalink)
Member: 127949
Thanks Meter: 32
micromax a065 mtk 6571 nand flash file needed
The Following User Says Thank You to mukaram For This Useful Post:
Old 01-27-2016, 14:08   #5 (permalink)
Member: 1188062
dead solution give urgent
Old 01-28-2016, 05:46   #6 (permalink)
deepak.'s Avatar
Member: 1825795
Sonork: 100.1621021:98
Thanks Meter: 183
hi
if usb conect then downlad flesh files and try to flesh it
Old 04-10-2016, 12:58   #7 (permalink)
Member: 2464111
Sonork: 100.1671169
Thanks Meter: 16
if usb is not detected what to do.....
Old 04-11-2016, 21:05   #8 (permalink)
arneja's Avatar
Member: 2401275
Thanks Meter: 78
If not detect open the phone and find kcolo/colo near volume button or behinde vol button and short kcolo short to ground your pc detect phone properly and flash...then flash complete and remove kcolo wire to ground and in set phone recover done.......
Old 07-08-2016, 14:52   #9 (permalink)
Member: 1248435
Thanks Meter: 28
pls give an image to show kcolo/colo or tp for flashing because the handset is in dead position usb is not detected
Old 07-11-2016, 08:56   #10 (permalink)
Member: 2508657
Sonork: 100.1623070
Thanks Meter: 380
Dear Friend,
U Can Seen Clearly Kcola Point In Main Board Just Assemble Phone And Open Eyes And See..
Thank U.....
Old 09-28-2016, 11:51   #11 (permalink)
Member: 1511238
Sonork: 100.1620450
Thanks Meter: 12
dear,team
mmx a069 history is hang on logo
flashing with above file,download from gsmhosting support area,but phone is dead.
than try to flshing other firmware but no luck.
so kindly help me,give me tasted flash file,to alive phone pls
Old 12-23-2016, 19:29   #12 (permalink)
Member: 2652079
Thanks Meter: 10
sir same problem here. previusly flash success a 065 . this time it is dead where is the problem please help
Old 12-24-2016, 05:30   #13 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Originally Posted by katuwalprem View Post
dear,team
Hello which Ver. You Flash After Dead Your Handset
Use THis Ver. And Post Here Result
If Same Problem Need Info. Back Side OF sticker On Your Phone
MMX_A065_SW_V1.0_HW_V1.0_270614
Download
The Following 6 Users Say Thank You to Deepesh Sharma For This Useful Post:
Page generated in 0.19579 seconds with 8 queries
