Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 07-11-2014, 06:42   #1 (permalink)
johnysofts's Avatar
Member: 319956
Thanks Meter: 124
micromax a069 flash file need
micromax a069 flash file need i want to hard reset it but fail
so i need its flash file if any body have please share
thanks
Old 07-11-2014, 07:43   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
Welcome to the ./downloads/Micromax/00_A Serie/A069/ folder of GsmHosting support area
Here it is (Daily fresh firmware and world 1st as usual)
if you have any problem in downloading from the support, please, have a look at this thread : http://forum.gsmhosting.com/vbb/f811...blems-1836081/
Alex
Note : I think this is the 1st handset MT6572 out of the box with Android KitKat 4.4.2 and has 512Mb Ram only
Old 07-11-2014, 13:46   #3 (permalink)
Member: 1490666
Sonork: altafsms44
Thanks Meter: 10
How To Hard Reset Micromax Bolt A069 & Remove Google Pattern Lock >> visit the Link click here now
Old 07-28-2014, 14:53   #4 (permalink)
Member: 67260
Thanks Meter: 146
Red face Micromax A069 Pattern lock
Sir bro,
This video can work . but how to enter wipe data/factory reset button i tried all button but no response any one know the solution pls reply
Thankyou.
Old 07-28-2014, 15:10   #5 (permalink)
Prem_India's Avatar
Member: 718725
Sonork: 100.1604953 QQ 2339690693
Thanks Meter: 6,702
Originally Posted by alexchairman View Post
Sir bro,
Thankyou.
Download Link Already Posted
Check Post#2 http://forum.gsmhosting.com/vbb/10429418-post2.html
Download : Welcome to the ./downloads/Micromax/00_A Serie/A069/Software Versions/V1_10.06.14/ folder of GsmHosting support area
B.R.,
Prem_India
Old 07-29-2014, 07:26   #6 (permalink)
Member: 67260
Thanks Meter: 146
Originally Posted by Prem_India View Post
Always say Public File Busy....
Old 07-29-2014, 08:27   #7 (permalink)
moulnisky's Avatar
Member: 947561
Never thought in your life about having a look at the sticky threads?
Alex
Old 07-31-2014, 10:24   #8 (permalink)
Member: 744454
Sonork: shakil
Thanks Meter: 26
please give flasher not in your download area
Old 07-31-2014, 10:49   #9 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
working again try now Refresh button, or try again later
new link uploading
Old 08-23-2014, 13:57   #10 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 216
thanks
volume+and volume_ +power botton then show red icon push power botton
recovery menu show then select factory reset by volume_ botton then touch left side first button on touch noe select yes then again touch frst button on touch now set will hard reset enjoy unlocking
Old 08-25-2014, 08:15   #11 (permalink)
Member: 656277
Thanks Meter: 187
bro. after show for wipe data not select any button & touch
i cheked many times
plz guide m
Old 08-27-2014, 14:21   #12 (permalink)
chinnivardan's Avatar
Member: 892484
Sonork: not using
Thanks Meter: 916
i cheked many times
plz guide m
yes not selecting wipe data
i think flashing is final solution
Old 08-27-2014, 16:32   #13 (permalink)
Member: 892484
Sonork: not using
Thanks Meter: 916
finally my problem solved ofter formatting user data in sp tool
open tool select scatter file
un tick all expect USER DATA and click on DOWNLOAD
i have og file so i used same file
but i think any same cpu scatter file (MT6572) works for this method
with same file i tested
if U don't have flash file try with other scatter file (MT6572) but try u r own risk
if works please reply comments and thanks to moulnisky for giving file
The Following 3 Users Say Thank You to chinnivardan For This Useful Post:
Old 08-30-2014, 11:38   #14 (permalink)
sangaistalin's Avatar
Member: 1474141
Sonork: 100.1647675
Thanks Meter: 66
micromax a069 pattern lock solved by me
mtk6572
use volcano tool to read info, then copy user data address then click format manuly put user data address click start problem finish
Old 08-30-2014, 12:22   #15 (permalink)
moulnisky's Avatar
Member: 947561
Not needed any tool : just press Vol+, Vol- and power on to enter factory mode (engineering code : *#64276#).
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Page generated in 0.20627 seconds with 10 queries
