Micromax General Micromax phones discussion, firmwares, solution, root, help |
07-11-2014, 07:43 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Welcome to the ./downloads/Micromax/00_A Serie/A069/ folder of GsmHosting support area Here it is (Daily fresh firmware and world 1st as usual) if you have any problem in downloading from the support, please, have a look at this thread : http://forum.gsmhosting.com/vbb/f811...blems-1836081/ BR Alex Note : I think this is the 1st handset MT6572 out of the box with Android KitKat 4.4.2 and has 512Mb Ram only Last edited by moulnisky; 07-11-2014 at 07:47. Reason: Note added |
07-11-2014, 13:46 | #3 (permalink) |
Insane Poster Join Date: Jan 2011 Location: m.p.
Member: 1490666 Status: Offline Sonork: altafsms44 Thanks Meter: 10 | How To Hard Reset Micromax Bolt A069 & Remove Google Pattern Lock >> visit the Link click here now |
07-28-2014, 14:53 | #4 (permalink) |
Freak Poster Join Date: May 2004 Location: INDIA Age: 46
Member: 67260 Status: Offline Thanks Meter: 146 | Micromax A069 Pattern lock Sir bro, This video can work . but how to enter wipe data/factory reset button i tried all button but no response any one know the solution pls reply Thankyou. |
07-28-2014, 15:10 | #5 (permalink) | |
Product Supporter Join Date: Mar 2008 Location: India
Member: 718725 Status: Offline Sonork: 100.1604953 QQ 2339690693 Thanks Meter: 6,702 | Quote:
Check Post#2 http://forum.gsmhosting.com/vbb/10429418-post2.html Download : Welcome to the ./downloads/Micromax/00_A Serie/A069/Software Versions/V1_10.06.14/ folder of GsmHosting support area B.R., Prem_India | |
07-29-2014, 07:26 | #6 (permalink) | |
Member: 67260 Status: Offline Thanks Meter: 146 | Quote:
07-29-2014, 08:27 | #7 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Never thought in your life about having a look at the sticky threads? http://forum.gsmhosting.com/vbb/f811...blems-1836081/ BR Alex |
08-23-2014, 13:57 | #10 (permalink) | |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | Quote:
recovery menu show then select factory reset by volume_ botton then touch left side first button on touch noe select yes then again touch frst button on touch now set will hard reset enjoy unlocking | |
08-25-2014, 08:15 | #11 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Uttar Pradesh India
Member: 656277 Status: Offline Thanks Meter: 187 | Quote:
bro. after show for wipe data not select any button & touch i cheked many times plz guide m | |
08-27-2014, 16:32 | #13 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hyderabad INDIA
Member: 892484 Status: Offline Sonork: not using Thanks Meter: 916 | finally my problem solved ofter formatting user data in sp tool open tool select scatter file un tick all expect USER DATA and click on DOWNLOAD i have og file so i used same file but i think any same cpu scatter file (MT6572) works for this method with same file i tested if U don't have flash file try with other scatter file (MT6572) but try u r own risk if works please reply comments and thanks to moulnisky for giving file |
The Following 3 Users Say Thank You to chinnivardan For This Useful Post: |
08-30-2014, 11:38 | #14 (permalink) |
Freak Poster Join Date: Dec 2010 Location: sankarankovil , tirunelveli Age: 38
Member: 1474141 Status: Offline Sonork: 100.1647675 Thanks Meter: 66 | micromax a069 pattern lock solved by me mtk6572 use volcano tool to read info, then copy user data address then click format manuly put user data address click start problem finish |
08-30-2014, 12:22 | #15 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Not needed any tool : just press Vol+, Vol- and power on to enter factory mode (engineering code : *#64276#). BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
