Micromax General Micromax phones discussion, firmwares, solution, root, help |
08-26-2015, 11:03 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2015 Location: faridabad(delhi) Age: 33
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | Micromax a093 imei repiar solved tested&og soloution A093 IMEI Writing Procedure WriteStation User Guide Environment Requirement 1.1. Hardware environment 1.1.1.Computer, CPU 1.7GHz or above, 512M ram or above 1.1.2.Monitor,the resolution is 1024×768 or above 1.1.3.Stabilized D.C. source (4.0V/2A) or full charged battery of mobile phone 1.1.4.Mobile phone 1.2. Software environment 1.2.1.OS: Window2000, XP 1.2.2.WriteStation program and HQ Framework 1.2.2.1 (a)First you should install the HQ Framework on your computer. Unzip the .rar file below and you will get a .exe file you should install it (b)Then you will get a dialog ****, choose the second item in drop down list to choose the Language of English, (c) Click “ok” you will get the next step: (d) Click next get Dialog below. Click the install button and the software will install on your computer. (e) Click finish and a dialog like Dialog 2 will appear that means you have installed the software successfully. (Dialog1) (f) Your desktop will appear a new icon like this: 1.2.2.2 Install Writestation TOOL: After install the software successfully, and your desktop will appear a new icon like this: 1.2.3.USB driver “MTK_USB_Driver_exe_v1.1032.0” or above 1.2.4.USB to COM driver “PL2303_Prolific_DriverInstaller_v1210” or above 1.3. Others 1.3.1.Power cable 1.3.2.USB data cable or UARR to USB cable 1.3.3.USB Hub when needed. Please note that USB Hub should be powered..... connection 2.1. Driver should be installed first, PL2303_Prolific_DriverInstaller_v1210 or above should be installed if UART is chosen as communication mode, MTK_USB_Driver_exe_v1.1032.0 or above should be installed if USB is chosen as communication mode, and Driver - USB VCOM Driver (binary) should also be installed if your handset is smart phone.Setup 2.2: HQ Framework should be installed before WriteStation tool was installed. Please keep default settings while installing. 2.3.At last, WriteStation tool should be installed, and please keep default settings while installing. 2.4.All tools or drivers are mentioned above can be download from: http://192.168.25.184/wiki/tools.html Write 4.1.Double click the icon show as below picture to run WriteStation:4.2.User interface of WriteStation 4.3. Set parameters Password: 20120405 4.4. Set platform information MTKFP: indicates feature phone platform of MTK, MTKSP: indicates smart phone platform of MTK Qualcomm: indicates Qualcomm platform, Spread: indicates Spread platform, YEP: indicates platform for Xi'an institute; THANX Bro here is your file click and download here one click download link if you like my post just press onlybutton _________________ B.R Abhay_Rana_Singh!!!! |
The Following 3 Users Say Thank You to abhayranasingh For This Useful Post: |
08-26-2015, 11:08 | #2 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | 4.5. Communication port set COM port:Set a communication port here, COM…should be set if UART is chosen as communication mode while USBCOM if USB is chosen as communication mode. Refresh:The list of com ports will be refreshed when “refresh” is clicked. PrintPort:User should choose a print port if user want to use print function.. 4.6. Data File select DB: please choose a database file here, database file should begin with “BPLGUInfoCustomApp” and with no suffix; AP: please choose an AP file, AP file should begin with “APDB” and with no suffix. PrintTMP:Please choose a print template file. The template file should as much like as supplied in help section. IMEI File:Please choose an excel file filled with IMEI. BT File: Please choose an excel file filled with BT. WIFI File: Please choose an excel file filled with WIFI. CSN File: Please choose an excel file filled with CSN. 4.7. Project information config 4.8. Test Item Config Print: print only Write: write number only Print&Write: write number first and then print these numbers. SN: SN writing will be enabled if this box is checked and disabled will unchecked. CSN: CSN writing will be enabled if this box is checked and disabled will unchecked. BT: BT writing will be enabled if this box is checked and disabled will unchecked. WIFI: BT writing will be enabled if this box is checked and disabled will unchecked. IMEI: BT writing will be enabled if this box is checked and disabled will unchecked. BTFlag: BTFlag writing or checking will be enabled if this box is checked and disabled while unchecked. Generally, if BTFlag is checked, tool will check the BTFlag. FTFlag: FTFlag writing or checking will be enabled if this box is checked and disabled while unchecked. Generally, if FTFlag is checked, tool will check the FTFlag. ANTFlag: ANTFlag writing or checking will be enabled if this box is checked and disabled while unchecked. Generally, if ANTFlag is checked, tool will check theANTFlag. CITFlag: CITFlag writing or checking will be enabled if this box is checked and disabled while unchecked. Generally, if CITFlag is checked, tool will check the CITFlag. ExtFile: If this box is checked, you can write extend File, otherwise, cannot write extend File; 4.9. SN Input Config SNCheck: User can checked this box and check while write SN; SNLength: Check SN Length; SNHeadString: check SN Head String; 4.10. SN Input Config Single: indicates that you want write one IMEI only into your handset; Double: indicates that you want to write two IMEI into your handset; Four: indicates that you want to write four IMEI into your handset; IMEI2-AutoCreate: IMEI2 will automatically counted according to IMEI1 if checked; D-value: the delta value between IMEI1 and IMEI2; FileAssign: decide if IMEI will be assigned automatically from the IMEI excel file configured at “IMEI File”; lowerRange1 and upperRange1 :indicate the lower range and upper range of IMEI1 respectively, if the low range value less than or equal to the upper range value, the tool will check IMEI1。 lowerRange2 and upperRange2 ,lowerRange3 and upperRange3,lowerRange4 and upperRange4:the function of lowerRange1 and upperRange1 similar respectively; NumAssign: decide if IMEI will be assigned automatically by Number in tool interface; BeginNum1, EndNum1 and CurrNum1:indicate the begin number, end number and current number of IMEI1 respectively; BeginNum2,EndNum2 and CurrNum2, BeginNum3,EndNum3 and CurrNum3, BeginNum4,EndNum4 and CurrNum4: function of BeginNum1,EndNum1 and CurrNum1 similar respectively; w8 soloution is not compleat another soloution in next post because only 15 image uploading capacivility on gsmhosting Bro here is your file click and download here one click download link if you like my post just press onlybutton _________________ B.R Abhay_Rana_Singh!!!! |
The Following User Says Thank You to abhayranasingh For This Useful Post: |
08-26-2015, 12:54 | #3 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | 4.11 CSN Input Config FileAssign: decide if CSN will be assigned automatically from the CSN excel file configured at “CSN File”; LowerRange and upperRange :indicate the lower range and upper range of CSN respectively, if the low range value less than or equal to the upper range value, the tool will check CSN。 NumAssign: decide if CSN will be assigned automatically by Number in tool interface; HeadNum,BeginNum,EndNum,CurrNum and Base: indicate the head number, the begin number, end number, current number and radix of CSN respectively; 4.12. BT Input Config FileAssign: decide if BT will be assigned automatically from the BT excel file configured at “BT File”; LowerRange and upperRange :indicate the lower range and upper range of BT respectively, if the low range value less than or equal to the upper range value, the tool will check BT。 NumAssign: decide if BT will be assigned automatically by Number in tool interface; BeginNum,EndNum and CurrNum: indicate the begin number, end number, current number and radix of BT respectively; 4.13. WIFI Input Config FileAssign: decide if WIFI will be assigned automatically from the WIFI excel file configured at “WIFI File”; LowerRange and upperRange: indicate the lower range and upper range of WIFI respectively, if the low range value less than or equal to the upper range value, the tool will check WIFI。 NumAssign: decide if WIFI will be assigned automatically by Number in tool interface; BeginNum,EndNum and CurrNum: indicate the begin number, end number, current number and radix of WIFI respectively; 4.14. Extend File Config ExtFile: User can Select extend File by Select button; 5: Write demonstration Note: all operation should be done when phone is powered off.A: Input SN and IMEI1 number by manual, others number like this; 5.A.1. Config the tool 5.A.2. Change to “Operation” panel, and then input SN, BT, WIFI, and IMEI correctly, and then click “Start” or press “Enter” directly to start write number. Tool will wait two minutes before phone connected, otherwise tool will stop automatically. User should power to the phone and then connect PC and phone via usb cable when count occur showing as the upper picture. 5.A.3. Operation complete soloution is compleated if any quire suggestion send mail [email protected] THANX Bro here is your file click and download here one click download link if you like my post just press onlybutton _________________ B.R Abhay_Rana_Singh!!!! |
The Following 4 Users Say Thank You to abhayranasingh For This Useful Post: |
08-27-2015, 08:45 | #5 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | no its not done them basbend is unknown its only work then basbend is true 1st repair basebend then try with this soloution |
08-28-2015, 12:29 | #7 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | sorry bro i dont have this file but i have a soloution find same handset read working .bin file with mircal,volcano etc... any chienes tool and write you a093 which u read file _________________ B.R Abhay_Rana_Singh!!!! |
