Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-03-2017, 10:13 | #4 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | what was the condition before flash ? is your mobile detect by pc ? try with another flash file (would be better if you use same version) , use professional tool to flash . |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
03-03-2017, 11:44 | #6 (permalink) | ||
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Quote:
if not make any port then open your hand set find KOLO print on your mobile board and short it with ground after connect usb cable now you see port on device manager now start flash with diffrent firmware. if make any kind of port in device manager need need to change your firmware ver. and flash again. or post here which ver. you need for flashing firmware | ||
