Micromax General Micromax phones discussion, firmwares, solution, root, help |
04-02-2016, 14:37 | #17 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: MUMBAI INDIA Age: 35
Member: 697969 Status: Offline Thanks Meter: 8 | Quote:
08-10-2016, 11:38 | #20 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2111687 Status: Offline Thanks Meter: 7 | sir i have flash with this file. but it was not booting up just 1 modem symbol only than i format it with AKA volcano inferno tool. now its dead. ygdp tool detect it. but it showing flash failed. and preloader boot keep disconnecting as soon as flash start. its customer phone. any solution? |
11-22-2016, 05:53 | #25 (permalink) |
No Life Poster Join Date: Nov 2015 Age: 25
Member: 2493574 Status: Offline Thanks Meter: 605 | you have done wrong man Select model in config i:e,7296s_ios select and flash every things will be ok Last edited by Shikhar12; 11-22-2016 at 05:54. Reason: spelling mistake |
The Following User Says Thank You to Shikhar12 For This Useful Post: |
04-21-2017, 04:16 | #26 (permalink) |
Major Poster Join Date: Dec 2015 Location: India
Member: 2503159 Status: Offline Thanks Meter: 14 | I've followed all the procedure correctly but ygdp can't connect my device in download mode. Is there any key combination to boot the device in download mode? I've tried volume up and down but no success, Volume up boots into recovery mode and if I press volume down and insert cable then it shows something like modem and volume up/down. If I just simply connect the device with data cable then it is connect for 1 sec or so and disconnect automatically and start charging. I know I'm bad in English, I hope you guys can understand what I am trying to say. Thanking you in advance |
