Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 07-11-2015, 08:30   #1 (permalink)
Member: 1807719
Sonork: 100.1619084
Thanks Meter: 30
Micromax a120 flashing problem
i had flashed my micromax a120 with sp flash tool
after that my phone has dead used firmware is-
Micromax_A120_V2_10.06.14_Kitkat
later i downloaded the older version firmware-Micromax_A120_V1_04.04.14
but when i tried to flash this phone this phone sp flash tool prompt me
an error that - BROM ERROR : S_DL_PMT_ERR_NO_SPACE (5069)
plz someone or any expert help how to solve this issue
Old 07-11-2015, 08:35   #2 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,873
hi
In new latest update sp tool use frimware update or. erasing option can use if u know how to erase and flash again
The Following User Says Thank You to DYNET For This Useful Post:
Old 07-11-2015, 08:44   #3 (permalink)
Member: 1807719
Sonork: 100.1619084
Thanks Meter: 30
plz reply how to erase the phone safely and which version of flash tool i did not know
Old 07-12-2015, 07:47   #4 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,873
solution is to NOT select "download" option on SP FLASH TOOL but select "Format All + Download"
Regards
DYNET
Old 11-06-2015, 03:51   #5 (permalink)
satwindershine's Avatar
Member: 1562820
Thanks Meter: 32
I have same problem with micromax a120 v11 not flashing any tool or any flash tool version 5069 error
Sent from my SGH-I317M using Tapatalk
Old 11-16-2015, 07:49   #6 (permalink)
Member: 1779909
Sonork: ak
same problam ?plz solution snd
Old 11-18-2015, 14:23   #7 (permalink)
Member: 1807719
Sonork: 100.1619084
Thanks Meter: 30
micromax_a120_v2_10.06.14_kitkat
later i downloaded the older version firmware-micromax_a120_v1_04.04.14
an error that - brom error : S_dl_pmt_err_no_space (5069)
once again my phone micromax a120 bricked by flashing with both files ,micromax product supporters why are you not sharing exact firmware for all micromax models
Old 11-18-2015, 18:41   #8 (permalink)
VIJAYMOURYA's Avatar
Member: 712406
Sonork: 100.1651933
Thanks Meter: 242
Change sp flash tool version
Which ver. Of sp tool you are using...try to use lower version of sp tool to flash old firmware
Old 11-19-2015, 04:42   #9 (permalink)
Member: 1022602
Thanks Meter: 10
sir use all version tool but not sucess my hansets also dead
Old 01-02-2016, 05:55   #10 (permalink)
Crazy Poster
Member: 2068970
Thanks Meter: 6
micromax a120
how to fix plz....help
Old 01-02-2016, 06:33   #11 (permalink)
Member: 1948608
Thanks Meter: 1,618
Originally Posted by MROJA View Post
micromax a120
You can try to write Any Ver.Firmware on EMMC Flash Type Based MTK Phone.(Do Not Try With MTK NAND And SPD NAND-EMMC)
Download Lower Sptool Ver. and Load Scatter,Go to ''Format'' Tab And Select ''Format Whole Flash'' After Finish Format,Press ''Download'' Tab And let Tool to Finish Flash.
Old 01-02-2016, 07:01   #12 (permalink)
Crazy Poster
Member: 2068970
Thanks Meter: 6
sir -- micromax a120 format ok
but download error
Old 01-02-2016, 07:27   #13 (permalink)
faisalkhan12345's Avatar
Member: 1969619
Sonork: 100.1670362 QQ3052215670
Thanks Meter: 1,575
but download error
just flashed with v1 version ur problem solved tested by me
Old 01-02-2016, 08:16   #14 (permalink)
Crazy Poster
Member: 2068970
Thanks Meter: 6
try to flash
but same error
Old 01-19-2016, 05:45   #15 (permalink)
Member: 2134654
Sonork: 1653132:rafeeqnr
Thanks Meter: 8
I have download all versions like v1 .v2 . V11 hw 1.1 but problem is same
Page generated in 0.36286 seconds with 7 queries
