Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 09-01-2015, 05:33   #1 (permalink)
Member: 1132141
Thanks Meter: 24
micromax a24 auto off
micromax a24 shows message then off
"phone will shut down after .. seconds"
any solution???
Old 09-01-2015, 05:51   #2 (permalink)
Member: 2422887
Thanks Meter: 42
any solution???
Try this version upgradedownload_r2.9.9009
The Following User Says Thank You to muzammilm01 For This Useful Post:
Old 09-03-2015, 13:10   #3 (permalink)
Cheater -Don't Deal with him-
Member: 2388887
Sonork: 100.1623070 QQ 3208774531
Thanks Meter: 1,202
Try flash yur handset then post result bro.......
Old 09-03-2015, 13:53   #4 (permalink)
Member: 1807719
Sonork: 100.1619084
Thanks Meter: 30
flash your phone with correct firmware
install spd drivers first
select PAC file in download tool
choose HW.img file
click play button
connect switch off phone using volume- or volume- to pc
flashing starts quickly
The Following User Says Thank You to rajugsm77735 For This Useful Post:
Old 09-04-2015, 09:46   #5 (permalink)
Member: 2388887
Thanks Meter: 1,202
download from here flash file ,flash tool
micromax a24
download
flash file : PZ330AW_KMOEB_DM280_MicromaxA24_FOREIGN_V1.2.7.zip
flash tool : topwise_UpgradeDownload(2013-12-18).zip
Bro here is your file click and download here one click download link
if you like my post just press onlybutton
_________________
B.R
Abhay_Rana_Singh!!!!
The Following 2 Users Say Thank You to abhayranasingh For This Useful Post:
Old 09-04-2015, 11:56   #6 (permalink)
Member: 2422887
Thanks Meter: 42
Sir flash file zip rar not open
Old 09-04-2015, 12:25   #7 (permalink)
Member: 2207555
Thanks Meter: 1,622
Wink
Hello There
Here is factory firmware of Micromax A24
Micromax A24 Firmware(AndroidXda)
RegaRds
Rehan sHaikH.
The Following User Says Thank You to rehansk8879 For This Useful Post:
Old 09-05-2015, 01:23   #8 (permalink)
Member: 2388887
Thanks Meter: 1,202
File is working dear plz check again
Sent from my iPhone using Tapatalk
Old 09-05-2015, 15:42   #9 (permalink)
Member: 1807719
Sonork: 100.1619084
Thanks Meter: 30
EXTRACT ZIP or RAR files using applications like
TZIP WINRAR then you will find tour desired stuff
Old 09-07-2015, 12:23   #10 (permalink)
Member: 2388887
Thanks Meter: 1,202
Wink update NEW FLASH FILE AND WORKING FLASH FILE LINK
micromax a24
download
_________________
B.R
Old 09-28-2015, 06:05   #11 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,017
100% sure battery problemes....................
The Following User Says Thank You to DHEERAJ_SHARMA For This Useful Post:
Old 09-29-2015, 11:20   #12 (permalink)
Member: 2388887
Thanks Meter: 1,202
Dear Deepak Bro Its Hdw PrOb By My WAy
Thanks..
Old 08-18-2017, 09:00   #13 (permalink)
bhalaygilani's Avatar
Member: 1647864
Thanks Meter: 80
I also faced this problem and found a result that is 100% hardware fault because phone was working in factory and recovery mode i.e hard reset and other tests were okay but after powering it up phone was in same condition even after hard reset ...so i powered on it with a supply with 3.8 voltages ..it worked well ...for me it was a q mobile i7i
this type of problem comes only with spd cpus....I am checking it and will post result if i succeeded to repair it
The Following User Says Thank You to bhalaygilani For This Useful Post:
Page generated in 0.25750 seconds with 8 queries
