Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 03-03-2014, 06:00   #1 (permalink)
Subhadeep's Avatar
Member: 1207045
Sonork: 100.1617234
Thanks Meter: 58
Micromax A28 After Flash Touch Not Work [Solution Available].
after format touch not work.....then i flash with og file...but no luck....any body have some informaqtion plz post....
Old 03-08-2014, 03:43   #2 (permalink)
Member: 2082450
Thanks Meter: 1,454
After formatting, give the details of ur phn condition.
Like display, phn heating, sound etc........
Old 03-08-2014, 14:08   #3 (permalink)
Subhadeep's Avatar
Member: 1207045
Sonork: 100.1617234
Thanks Meter: 58
every thing ok but Touch not work
Old 03-08-2014, 16:06   #4 (permalink)
Member: 2082450
Thanks Meter: 1,454
Flash it again with stock firmware.... and then check the tp.
If problem persists, then try a new tp to check the old one
Old 03-08-2014, 21:48   #5 (permalink)
Member: 2142840
Thanks Meter: 5
Insert battery and Press and Hold Power+Volume up+Volume down together (different phones might have a little different method of booting into recovery mode, but this is the most general one).
You will then boot into recovery mode , use volume keys to navigate up and down and power key to choose.
Choose Wipe DATA
Choose wipe cache.
Reboot device.
Old 07-23-2014, 13:52   #6 (permalink)
Member: 2227568
about hard reset of micromax a28
according to your instruction first download alladdin tool then hard reset micromax a28 but this is easy plz tell another way to remove pattern lock of micromax a28
thank you
Old 07-23-2014, 14:11   #7 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
do not flash only read hare image 100% done
http://s30.postimg.org/7prjetdm9/Fast_Stone_Editor.png
Old 07-23-2014, 14:13   #8 (permalink)
Member: 514136
Thanks Meter: 19
Ze230paa_060a_v8_0_0
Old 07-23-2014, 14:14   #9 (permalink)
Member: 514136
Thanks Meter: 19
Bro try thish flash file 10000% tested ZE230PAA_060A_V8_0_0
Old 09-18-2014, 15:18   #10 (permalink)
Member: 906976
after flash just press vol up key go to factory test now - ctp update FW
after update exit just try & post result
The Following User Says Thank You to rishi1981 For This Useful Post:
Old 10-03-2014, 15:32   #11 (permalink)
Member: 2266955
good jog 10000000% working
Old 04-22-2016, 14:51   #12 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
thanks you save a day ...
touch works after update first option ...
Old 12-19-2017, 12:17   #13 (permalink)
Member: 500885
Thanks Meter: 77
micromax a28 bold touch not working after flash
full flash ctp update fw but no luck anybody help me
Page generated in 0.20895 seconds with 8 queries
