Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-03-2014, 06:00 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: In GSM Field
Member: 1207045 Status: Offline Sonork: 100.1617234 Thanks Meter: 58 | Micromax A28 After Flash Touch Not Work [Solution Available]. Last edited by rmarconcini; 04-24-2016 at 02:17. Reason: More effective title |
03-08-2014, 21:48 | #5 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2142840 Status: Offline Thanks Meter: 5 | Insert battery and Press and Hold Power+Volume up+Volume down together (different phones might have a little different method of booting into recovery mode, but this is the most general one). You will then boot into recovery mode , use volume keys to navigate up and down and power key to choose. Choose Wipe DATA Choose wipe cache. Reboot device. |
07-23-2014, 13:52 | #6 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2227568 Status: Offline Thanks Meter: 0 | about hard reset of micromax a28 according to your instruction first download alladdin tool then hard reset micromax a28 but this is easy plz tell another way to remove pattern lock of micromax a28 thank you |
09-18-2014, 15:18 | #10 (permalink) |
Junior Member Join Date: Nov 2008
Member: 906976 Status: Offline Thanks Meter: 1 | after flash just press vol up key go to factory test now - ctp update FW after update exit just try & post result |
The Following User Says Thank You to rishi1981 For This Useful Post: |
