Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 08-15-2015, 00:42   #1 (permalink)
amit kanpur's Avatar
Member: 1033905
Sonork: amitsharma
Thanks Meter: 892
Arrow Micromax A310 after flash factory mode..FIXED
today i flash micromx A310 ..after flash phone gone only recovery mode only , i will try all 3 version but same problem faced.
after flash......
here recover solution..
download here small file Dev-Host - Factory mode fix by Pinto.zip - The Ultimate Free File Hosting / File Sharing Service
1. Download and extract all the Files in a folder that's easy to find
2. On ur Phone then connect it to a PC
3. Open cmd to run as administrator
4. type- adb shell
5. Type-
-b fctd normal or fctest system reboot
6.Press Enter
7. Phone will restart automatically,
8. Click "unFactroy Mode.bat" when open cmd screen press Enter, wait for it to finish and then press Enter again, Phone again will restart automatically and return to normal
RECOVER DONE....
BRO..
AMIT SHARMA
The Following 6 Users Say Thank You to amit kanpur For This Useful Post:
Old 12-04-2015, 13:11   #2 (permalink)
Member: 2036611
plz download file toany other site..like media fire or 4shared
Old 12-07-2015, 06:59   #3 (permalink)
Member: 1418692
Thanks Meter: 8
attach the handset with pc through usb cable
Extract the adb folder and copy to c:/drive
open command prompt.
Write following commands
cd C:/adb
adb devices
adb shell fctd -b normal
handset will restart automaticaly to normal mode
The Following User Says Thank You to shadabmnp For This Useful Post:
Old 12-07-2015, 07:11   #4 (permalink)
Member: 1418692
Thanks Meter: 8
this is a good link
factory mode solution - Download - 4shared
Old 01-31-2016, 06:54   #5 (permalink)
Member: 1004553
Sonork: imran007
Thanks Meter: 15
Dear friends ,I flashed A310 by YGDP TOOL succesfully.But set restarting logo only,Its connecting with fastboot mode only not in ADB mode.Any tricks?
Old 07-09-2016, 16:40   #6 (permalink)
Member: 1323417
Sonork: 650150323
Thanks Meter: 61
adb shell fctd -b normal working solution
Old 09-02-2016, 12:44   #7 (permalink)
babu lal saini's Avatar
Member: 1935677
Thanks Meter: 22
[QUOTE=shadabmnp;11459225]attach the handset with pc through usb cable
cd C:/adb
adb devices
this method not working
please give me tested soluion
handset attechment list error problem
Old 12-30-2016, 19:02   #8 (permalink)
Member: 554849
Thanks Meter: 24
the correct method is here 100000000% tested:
2. On your Phone then connect it to a PC
4. type adb shell
5. Type:
fctd normal
press enter
Type:
Press Enter
Old 05-11-2017, 16:39   #9 (permalink)
Member: 1460654
Sonork: 1234
Thanks Meter: 2
micromax a311 factery mode after saucessfuly flash, how to remove any body help me,it is veary urgent
Old 10-03-2017, 21:34   #10 (permalink)
Member: 2764188
micromax a311 factory mode
Old 10-04-2017, 06:02   #11 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
use same command you will fix it.
Old 10-10-2017, 15:11   #12 (permalink)
Member: 2587820
Thanks Meter: 2
thanks its working solution
Old 11-05-2017, 17:38   #13 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 617
after flash......
4. type- adb shell
5. Type-
6.Press Enter
RECOVER DONE....
BRO..
AMIT SHARMA
cd C:/adb
adb devices
[QUOTE=babu lal saini;12019592]
cd C:/adb
adb devices
4. type adb shell
5. Type:
fctd normal
press enter
Type:
Press Enter
here uploaded all commnd try but fhon is saame condition pls give mi tested solution
Old 05-31-2019, 22:13   #14 (permalink)
Member: 2643735
Thanks Meter: 6
Can u provide me file link a310?
Sent from my SM-G928G using Tapatalk
Page generated in 0.21584 seconds with 8 queries
