Micromax General Micromax phones discussion, firmwares, solution, root, help |
09-28-2016, 07:13 | #1 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2333593 Status: Offline Sonork: [email protected] Thanks Meter: 0 | micromax a311 flashing problem I have also a flash files or tool. But tell me how to I connect that device in flashing I instaal all mtk drivers now |
09-28-2016, 07:35 | #3 (permalink) |
Member: 2333593 Status: Offline Sonork: [email protected] Thanks Meter: 0 | First thanks friend to reply my post I have also a flash file or tool but problem is this my device connect in comport mtk port but the ygdp tool can't detect this my device in cell How to I connect my device in ygdp tool please solve my this problem |
09-28-2016, 11:37 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Hello . Isn't there s scatter file in your firmware ?if yes. Use SP_Flash_Tool_v5.1452.00.000 . Select Scatter then Select firmware Upgrage , reconnect battery then Connect Phone.. Wait few mins & done! (make sure u flash proper firmware). Or CPB file? Last edited by .::TEAM CCS::.; 09-28-2016 at 11:44. |
09-28-2016, 12:14 | #5 (permalink) |
Member: 2333593 Status: Offline Sonork: [email protected] Thanks Meter: 0 | no sir,i have no scatter file |
10-01-2016, 08:42 | #8 (permalink) |
Member: 2333593 Status: Offline Sonork: [email protected] Thanks Meter: 0 | this device unfortunately applications sttoped problem.. |
10-05-2016, 10:14 | #9 (permalink) |
Member: 2333593 Status: Offline Sonork: [email protected] Thanks Meter: 0 | no solution this problem? |
02-02-2017, 13:15 | #11 (permalink) |
Insane Poster Join Date: May 2009 Location: north india,,, himachal
Member: 1032503 Status: Offline Thanks Meter: 16 | Hello... the actual problem here as faced above is that the files for A311 is flashed with YGDP tool which supports qualcom cpu... But today as i am trying to flash a similar A311, it detects MTK6592 cpu not qualcomm... I tried in 3 different laptops, all showing mtk preloader ... So, driver is not an issue here... The issue is wrong software... This Micromax A311 Sticker says H/w Ver: P1 S/w Ver. 4.4-012 Even Inferno MTK is detecting as MTK6592 cpu... but fails to read full info... So here we need MTK flash File and not qualcom file as available... |
03-09-2017, 07:21 | #13 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 744022 Status: Offline Thanks Meter: 33 | http://mtk-p.micromaxinfo.com/produc....8297W_I02.rar and if ur mobile stuck on factory mode try these comands in fastboot mode adb shell "fctest system reboot" |
The Following User Says Thank You to DR MKOU For This Useful Post: |
01-18-2018, 15:00 | #14 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | for ygdp tool to detect phone need only "preloader usb vcom driver" other will not work. no need to insert battery connect direct usb cable without pressing anything. |
The Following User Says Thank You to djj007 For This Useful Post: |
