Micromax General Micromax phones discussion, firmwares, solution, root, help |
07-03-2013, 05:50 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 59 | Rooting Guide For Micromax A51 Bolt First In The World Disclaimer: This method of rooting micromax A51 worked successfully with my phone. Micromax A51 Bolt Baseband: bcm21553, Android ver:2.3.7 Kernel version: 2.6.35.7 I am not responsible if it does not work with your phone or if any harm is caused to your device. Although it is safe. Requirements: 1. Windows 7/8/xp 2. USB data cable Softwares and drivers required: 1. USB drivers/ Adb drivers( pdanet) 2. Broadcom drivers 3. Unlockroot.exe ver:2.3.1 4. Any file extractor: Winrar , 7Z etc. Download Links: 1.Download A51 broadcom drivers from here: (in downloads) Micromax Bolt A51 | Dual Sim Android Smartphone, Android 2.3 Gingerbread, Buy Smartphones 2.Pdanet installer for win7/8 is here: Download PdaNet+ Pdanet for WinXp: Download PdaNet 3.Download links for Unlockroot.exe: unlockroot23 - Download - 4shared or unlockroot23.exe Important: 1. Please disable Antivirus software on your PC until procedure is complete. So that it does not interrupt driver installation etc. 2. Uninstall Antivirus ,firewall etc applications from your android phone if you have installed. 3. In your android Go to Settings-Applications and (a) Tick Unknown sources [√] to allow non market applications. (b) In Development –Tick USB debugging to allow usb debugging. Procedure: Now come to Main procedure. Part 1: Installing USB and ADB drivers: ( With the help of Pdanet) 1. Install pdanet.exe on your pc. Follow the instructions properly. 2. Select other from device list. 3. Window will show security message. Click Install drivers Anyway. 4. Connect your device and pdanet will install USB/Adb drivers for your device. 5. To confirm, Go to Control panel –Device Manager and you should find there- Android phone- -ADB interface. Part 2: Installing Broadcom drivers: Note: Please disconnect your phone before installing Broadcom drivers. 1. With winrar or 7z, extract A51driver.rar any where in your pc. 2. There is a zip folder USB install 1.8.6.27 in win7 folder. Extract it. 3. You will get two applications. One for win7 and another for win xp. 4. Double click and install drivers suitable for your window version. 5. Read and follow instructions carefully. 6. Click Install Drivers anyway if Windows displays security message. 7. Now switch off your phone. Take battery out. Re-insert battery. Do not switch on. Connect your device with USB cable. Window will install drivers for your device. And show message that Device is connected successfully. 8. If there is any error .Repeat step 7 again. Or Try through other USB ports . 9. If drivers installed successfully then to confirm go to Control panel-Device Manager and check -PORTs ..There should be displayed Broadcoam Port no. Now we are ready to root. Part 3: Rooting Device: Note: Disconnect internet connection of pc before installing and running unlockroot.exe. Otherwise adds , popups etc will disturb you. 1. Switch on your phone normally. 2. Again Check that USB debugging is enabled and Unknown sources applications are allowed. 3. Install Unlockroot.exe (2.3.1) in your PC. 4. Run unlockroot.exe 5. Connect your A51 with usb cable. 6. Click Root. 7. Click “brcm Micromax A51” in device list. 8. Wait until Root is successful. 9. It will ask to reboot your device. Click yes. 10. Look for superuser app in app drawer. Congrats you are rooted now. • Download Root checker from play store to confirm. • Download Busybox from play store and install in /system/bin. All Credits Goes to Love864, Nave ................and A51 Develpment Members |
08-25-2013, 13:55 | #2 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2010532 Status: Offline Thanks Meter: 0 | Hyder - Help needed for Micromax A51 Hi, Please I need your advice only as I am writing this email from outside India, I have purchased Micromax Bolt A51 2½ months ago from India during my visit, the phone was working fine but for almost a week now it is stuck on Start-up and Staying on start screen written BOLT and again resetting and staying on same screen and not moving further. Please, I shall be so truly thankful if you can suggest if there is a way to reset my phone anyway from here as I am away from India, I’ve tried to find any suggestions on internet but didn’t had much luck. I am writing this email with lots of hope and I am expecting just a reply with the process to again let my phone work. Thank you once again in advance. |
11-12-2013, 18:12 | #3 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2064087 Status: Offline Thanks Meter: 0 | I have used micromax a51..but it's so slow.. Don't proper work .. So i have decide root this phone . How much possibality to the perfect the root? and which type problem is comming? ple give me info.. |
11-28-2013, 13:05 | #6 (permalink) |
Member: 2069190 Status: Offline Sonork: [email protected] Thanks Meter: 0 | micromax a51 restart i will install adb drivers and broadcom drivers can not show bordcom port please help me very very argent bro |
11-30-2013, 15:25 | #7 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | my set dead after flash now not detected by pc |
04-27-2014, 06:29 | #9 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2175702 Status: Offline Thanks Meter: 0 | change IMEI number of micromax a51 hiiii, could u plz guide me how to change IMEI number of micromax a51 mobile. I mistakenly deleted it while flashing the phone using bcm tool. now I am not able to call and even text. if u know how to do so, let me know asap. |
04-27-2014, 08:06 | #10 (permalink) | |
Freak Poster Join Date: Aug 2008 Location: azamgarh india
Member: 831885 Status: Offline Thanks Meter: 10 | Quote:
08-01-2014, 02:42 | #11 (permalink) |
Insane Poster Join Date: Jul 2012 Location: apple mobile durbar main gate
Member: 1790945 Status: Offline Thanks Meter: 6 | it may detect again ...try some tricks gien below.. i think ...it z dead becos of proper file .so find another file or download it again a fress file just disable ur antivirus for some time and as u flashed it by that brodcomm flasher select another file and the same prosces u have to follow as u followed before ....ONE THING U HV 2 CARE ONLY IS CHECK UR BATERY BY MULTIMETER IT SHOULD B ABOUT 3.9V CHARGE OR MORE IF IT Z NOT THEN BOOST IT OR USE UNIVERSAL CHARGER ....AND WHEN UR FLASHER TRIES TO CONECT UR MOBILE SUDDENLY PUT BATRY IN UR MOBILE FOLOWING ALL PROPER KEYS IT WIL B DETECTED BY UR FLASHER ..I V TRIED AND SUCCED ...IT MAY HELP U... |
