Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 07-19-2014, 14:39   #1 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
micromax a35 pattern lock problem
How to remove pattern lock of micrpmax a35 without loosing any data becouse it is used in any case and this mobile is send me by SP.
Remember without loosing any data how to remove pattern lock
One thing more USB debugging is no open.
Thanks in advance
The Following User Says Thank You to mahzra azra For This Useful Post:
Old 08-23-2014, 19:23   #2 (permalink)
sahier hossain's Avatar
Member: 1923587
Sonork: 100.1658149
Thanks Meter: 543
with out usb debugging
remove pattern unlock with out loss data
see dis bro maybe its help u................http://forum.gsmhosting.com/vbb/f723...-lock-1833699/
MN_sahier hossain
Old 09-09-2016, 07:29   #3 (permalink)
krishmobitech's Avatar
Member: 2569641
Sonork: WHATS APP & F.B
Thanks Meter: 657
micromax a35 pattern lock password lock...done in miracle loader (with out box)
[QUOTE=mahzra azra;10445354]How to remove pattern lock of micrpmax a35 without loosing any data becouse it is used in any case and this mobile is send me by SP.
Thanks in advance[/QUOTE
download miracle loader.......https://docs.google.com/uc?id=0ByTkx...xport=download
open miracle loader....turn off anti virus before...
select spd tab...
select cpu 8810-6820...
select root (adb)
press vol + power buton 2.3 seconds ...your now in fastboot mode
click start buton........you see roted masage.....
diconect usb cable ...remove batery..
select format
select advanced..
click on start buton...press vol- conect usb cable...one box is coming this proses...
click on ok......... n joy.......
10000000000000000000% ok tested by me........
Old 09-09-2016, 07:34   #4 (permalink)
Member: 785606
Sonork: liey
Thanks Meter: 5
use miracle box
click mtk
unlock fix
read pattern tested many times
Old 09-09-2016, 07:35   #5 (permalink)
Hamid memon786's Avatar
Member: 2255989
Sonork: 1001675246
Thanks Meter: 47
Im using volcano and volcano best and secure unlock pattern lock without wipe data
Page generated in 0.16054 seconds with 8 queries
