Micromax General Micromax phones discussion, firmwares, solution, root, help |
06-16-2014, 07:22 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: in earth
Member: 333037 Status: Offline Sonork: 100.1611244 Thanks Meter: 77 | micromax a36 flash file toll plz |
06-16-2014, 09:33 | #2 (permalink) |
Freak Poster Join Date: Oct 2011 Location: india,,,jammu
Member: 1668548 Status: Offline Sonork: 100.1647046 Thanks Meter: 24 | mmx 136 full f8810_6820_HYNIX H8BCS0UN0MCR..... i have tested on two mob...it works ok but may be need to check r IMEI no,,,, |
06-16-2014, 09:36 | #3 (permalink) |
Member: 1668548 Status: Offline Sonork: 100.1647046 Thanks Meter: 24 | ur flash file mmx 136 full f8810_6820_HYNIX H8BCS0UN0MCR..... i have tested on two mob...it works ok but may be need to check r IMEI no,,,, |
06-16-2014, 10:40 | #5 (permalink) |
Member: 1668548 Status: Offline Sonork: 100.1647046 Thanks Meter: 24 | ResearchDownload_2.9.8004 bro install MICROMAXX a6 drivers then open flashing tool & LOAD the flash file which is in .PAC format then put usb cable & connect to pc then click on START.......w/o driver the set not goes ONN press VOLUME - & the at last put BATTERY |
06-17-2014, 08:52 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | use the original OG file Welcome to the ./downloads/Micromax/00_A Serie/A36/Software Versions/V1_22.11.2013/ folder of GsmHosting support area extract the .pac file from the zip file and flash it using upgradedownload BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
