Micromax General Micromax phones discussion, firmwares, solution, root, help |
02-06-2015, 07:07 | #1 (permalink) |
Insane Poster Join Date: Dec 2011 Location: Nanded Age: 39
Member: 1707613 Status: Offline Thanks Meter: 11 | Micromax Ninja A27 Hard Reset Press and Hold Volume Down + Power Key for30-40 Seconds. Now you See Fastboot mode on screen. Now Download Android Multi Tool Download fastboot driver and install Drivers now open tool and press "8" and enter to wipe data / factory reset. after format remove battery and reinsert bettry. power on the handest. |
02-06-2015, 07:08 | #2 (permalink) |
Member: 1707613 Status: Offline Thanks Meter: 11 | Micromax A30 Hard Reset 1. Switch Off Your Phone 2. Press and hold Volume Down + Volume Up + power on button 3. Wait for 5 second And Press Home Button Then You See Android System Recovery menu appear 4. There are Many options * Reboot System Now * Apply Update from Sd card * Wipe data/factory reset * wipe cache partition 5. Move the Selection to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, Then Conform It because the touchscreen doesn't work in recovery mode 6. Then Choose Reboot System Now 7. After the process done, phone will reboot. |
