Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 04-25-2014, 13:12   #1 (permalink)
Member: 1019173
Sonork: crown mobile
Thanks Meter: 37
micromax A59 -- how to reset gmail lock
I try vol down + power, not work
The Following User Says Thank You to mohd.asim For This Useful Post:
Old 04-25-2014, 13:26   #2 (permalink)
mobite's Avatar
Member: 1800009
Sonork: 100.1654307
Thanks Meter: 806
micromax a59 pattern lock done 10000%
micromax a59 pattern lock done 10000% i tried many solution but this one is sucess just press on off when bolt appear click volume down leave androied logo comes then select option .
The Following 3 Users Say Thank You to mobite For This Useful Post:
Old 04-25-2014, 14:16   #3 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
Yes vol down and power button works just keep trying..!
Old 04-26-2014, 08:14   #4 (permalink)
Member: 1019173
Thanks Meter: 37
vol down + power button not work, i try again and again not work
and volcano box
anayalsis flash internal data fail
Old 04-26-2014, 11:52   #5 (permalink)
Member: 127949
Thanks Meter: 32
i have format with box now phone is dead any way to revive i tried flashing but bkfnv problem is coming..........
Old 05-03-2014, 12:05   #6 (permalink)
Registered User
Member: 645764
Thanks Meter: 208
i try it working fine. power on immediately press volume down button it working fine................................
The Following User Says Thank You to ka jagan For This Useful Post:
Old 08-25-2014, 11:44   #7 (permalink)
Member: 1577206
Sonork: amila123
Thanks Meter: 6
The Following User Says Thank You to amilacell For This Useful Post:
Old 10-07-2014, 15:03   #8 (permalink)
ashish800's Avatar
Member: 1889562
Thanks Meter: 617
The Following User Says Thank You to ashish800 For This Useful Post:
Old 11-09-2014, 08:49   #9 (permalink)
Member: 1679849
Sonork: 100.1623391
Thanks Meter: 6
thnks bro volume dwon press before bolt logo apear
Old 11-10-2014, 09:47   #10 (permalink)
Member: 2023985
Sonork: WhatsApp
Thanks Meter: 314
Flash With Official File and Tool
Download Flash File micromax a59 v1 ZSW230AA_060A_V8_0_2
Download Tool
Download Tool
Old 12-25-2014, 07:34   #11 (permalink)
Member: 1122969
Thanks Meter: 13
Miromax A59 reset gmail lock Done.
Volume Down Key 100% Working Test.
Battery Maxum 50% Try THis Solution Working
Old 03-04-2015, 14:23   #12 (permalink)
Member: 1996652
brother try with reserch download r2.9008.
Old 03-05-2015, 11:42   #13 (permalink)
Member: 212483
Sonork: 100.1638039
Thanks Meter: 4
do not formet flash only user data untick all other option in miracle use any version file no risk 100% tested
Old 04-05-2015, 07:42   #14 (permalink)
Member: 1676233
Sonork: 100.1648996
Thanks Meter: 3
i tried this 1000000000%ok
press on/off key & then press vol down
see android menu
wipe data @ hard reset set is ok............... thanks
Old 05-10-2015, 08:46   #15 (permalink)
Hatimhunk5's Avatar
Member: 2117717
Sonork: 100.1663585
Thanks Meter: 28
Micromax A59 Pattern Lock Procedure
1. Press On/Off Key
2. Immediately press Volume Down Key Before Come
Bolt Logo Note:- Phone should not be Vibrate than Immediately
Press Volume Down Untill Come Android Logo
3. Select Wipe Data to Reset Phone
The Following User Says Thank You to Hatimhunk5 For This Useful Post:
Page generated in 0.24283 seconds with 8 queries
