micromax a62 hard reset please help |
Micromax bolt a62 hard reset wipe data method |
micromax 62 FLASHING CABLE PROB PLZ HELP |
micro max a62 how to reset with out code |
press vol- down button and power key some time set will show fast boot mode then insert cable open anroid multi tool .press 8 button on your pc keyboard .wipe one |
volume down and power button then android symbol usb connect and android multi toos v01.2b 5 no. button press 1000% solution. |
can anyone post the latest firmware for micromax A 62 |
Press and Hold Volume Down + Power Key for 20-30 Seconds. Now you See Warning Logo on screen. Now Download Android Multi Tool Download fastboot driver and install Drivers now open tool and press "8" and enter to wipe data / factory reset. after format remove battery and reinsert battery. power on the handset. press thanks if u like my post....:) |
may b your vol button nt working change it then try |
root your a62 then use adb cmd for factory reset ! |
Micromax A62 Google Account & Pattern Unlock Done.. http://forum.gsmhosting.com/vbb/f811...-done-1723871/ Enjoy..... Br-Sanjeev Chauhan India |
[ROOT] Micromax A62 How to root Micromax a62 easily 1. Before You Begin 1. This will void the warranty of your device ! 2. Use at own your risk ! 3. Backup your rom ! 4. I am not responsible if anything bad happens ! 2. Requirements to root 1. Charge your battery upto 70% 2. Micromax a62 driver 3. Enable USB debugging - go to in Settings>Application>Development>USB debugging 4. Supersu from play store 5. Root Master 3. Let's start 1. Install micromax a62 driver in pc ! 2. Install Root master in pc ! 3. Sure you ticked the USB debugging ! ? http://static.dyp.im/OuWrGhjOHv/e53d...c302164988.PNG 4. Connect your device to pc ! 5. Open Root master and follow or click on red rectangle http://static.dyp.im/fjHHM96JQt/8032...0b0997a247.PNG 6. Follow and click on red rectangle-which i am showing in this picture ! your device is now connected to this software http://static.dyp.im/SqGz5dQAOf/5746...7bfb8d5d59.PNG 7. Click on root and wait ! it's will automatically reboot your device http://static.dyp.im/DwTmEpnZTI/1780...d5baf902f6.PNG 8. Your device is now rooted ! and now exit the root master http://static.dyp.im/N0y94mqWMv/8bfe...020fea0a7b.PNG 9. You can see this chiness superuser in your menu! http://static.dyp.im/59Iyog1XPR/b320...116d08e857.PNG 10. Install supersu or open if already installed ! and grant permisson like this http://static.dyp.im/74uuXd6GQ3/b3f6...2a93d2535a.png 11. supersu will automatically install su binary (need internet connection)! just grant the permisson and let the supersu uninstall Chinese superuser http://static.dyp.im/YaFRyn8NO1/1c79...edba151fac.PNG Your device is now rooted http://forum.xda-developers.com/imag...es/victory.gif ,you can also apply this method on other chiness or spreadtrum devices ! it's safehttp://forum.xda-developers.com/imag...rs-crossed.gif if you want to root your other devices then just pm me, i will tell you http://forum.xda-developers.com/images/smilies/wink.gif thank you very muchhttp://forum.xda-developers.com/imag...ies/tongue.gif [APP][ROOT] Android 4.1.2 Rooting Universal Method This method is single for rooting your mobile! [install] 1. Download Root Explorer [Google Play] 2. Download Root Master 3. Unpack and install Root Master on your PC 4. Install drivers of your mobile 5. Run RootMaster and press first button on first screen 6. After this click the center button on all windows 7. You mobile is rooted - Reboot your mobile 8. Close the RootMaster 9. Install Root Explorer and delete superuser.apk 10. This release of superuser.apk is not english http://forum.xda-developers.com/imag...lies/smile.gif 11. Delete or replace your superuser.apk in /system/app 12. Unpack Superuser.apk from zip and copy to /system/app folder 13. Reply yes to replace your apk Superuser.apk 14. If you delete superuser.apk reinstall Only superuser from Zip Root Master Download http://www.4shared.com/rar/hfs9oani/rootmaster.html Superuser 3.1.3 Free http://www.4shared.com/zip/KbSjKbGD/Superuser-313-arm-signed.html Enjoy..... Br-anabhi XDA Source : anabhi - XDA Developers |
Micromax a62 hard reset done MICROMAX A62 HARD RESET DONE phone must be on open Android Multi Tools connect usb cable than pres 5. |
hi. i have followed the procedure as mentioned, but when i press 8 ; it says < waiting for device >. but whn i redo the same n press 1 i shows device connected , after then when i press 8 it shows < waiting for device > how long does it shows like that i waited for long time but nothing happened. Pls help me |
