Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 07-01-2013, 11:34   #1 (permalink)
Member: 1407462
Sonork: kapilsh1977
Thanks Meter: 3
micromax a62 hard reset please help
sir plz tell me micromax a62 hard reset please help
Old 07-08-2013, 07:22   #2 (permalink)
Member: 1970272
Micromax bolt a62 hard reset wipe data method
Old 07-08-2013, 09:32   #3 (permalink)
Member: 565409
Thanks Meter: 21
micromax 62 FLASHING CABLE PROB PLZ HELP
Old 09-01-2013, 08:00   #4 (permalink)
Member: 1883835
micro max a62 how to reset with out code
Old 09-02-2013, 07:56   #5 (permalink)
shailccna's Avatar
Member: 350232
Thanks Meter: 192
press vol- down button and power key some time set will show fast boot mode then insert cable open anroid multi tool .press 8 button on your pc keyboard .wipe one
Old 09-02-2013, 15:38   #6 (permalink)
Member: 912556
Thanks Meter: 24
volume down and power button then android symbol
usb connect and android multi toos v01.2b 5 no. button press
1000% solution.
Old 10-05-2013, 10:03   #7 (permalink)
Member: 1967874
Thanks Meter: 3
can anyone post the latest firmware for micromax A 62
Old 10-05-2013, 10:16   #8 (permalink)
Member: 727810
Sonork: 100.1627301
Thanks Meter: 156
Press and Hold Volume Down + Power Key for 20-30 Seconds.
Now you See Warning Logo on screen.
Now Download Android Multi Tool
Download fastboot driver and install Drivers
now open tool and press "8" and enter to wipe data / factory reset.
after format remove battery and reinsert battery.
power on the handset.
press thanks if u like my post....
Old 10-09-2013, 08:04   #9 (permalink)
Member: 727810
Sonork: 100.1627301
Thanks Meter: 156
may b your vol button nt working change it then try
Old 10-10-2013, 12:44   #10 (permalink)
Member: 2035031
root your a62 then use adb cmd for factory reset !
Old 10-10-2013, 15:43   #11 (permalink)
Sanjeev_Chauhan's Avatar
Member: 1663011
Sonork: 100.1609944 QQ.1504180136
Thanks Meter: 1,585
Micromax A62 Google Account & Pattern Unlock Done..
Enjoy.....
Br-Sanjeev Chauhan
India
Old 10-11-2013, 08:42   #12 (permalink)
Member: 587669
Thanks Meter: 2
brother how to root device when pettern lock?????
Old 10-12-2013, 15:15   #13 (permalink)
Member: 2035031
[ROOT] Micromax A62 How to root Micromax a62 easily
1. Before You Begin
1. This will void the warranty of your device !
2. Use at own your risk !
3. Backup your rom !
4. I am not responsible if anything bad happens !
2. Requirements to root
1. Charge your battery upto 70%
2. Micromax a62 driver
3. Enable USB debugging - go to in Settings>Application>Development>USB debugging
4. Supersu from play store
5. Root Master
3. Let's start
1. Install micromax a62 driver in pc !
2. Install Root master in pc !
3. Sure you ticked the USB debugging ! ?
4. Connect your device to pc !
5. Open Root master and follow or click on red rectangle
6. Follow and click on red rectangle-which i am showing in this picture ! your device is now connected to this software
7. Click on root and wait ! it's will automatically reboot your device
8. Your device is now rooted ! and now exit the root master
9. You can see this chiness superuser in your menu!
10. Install supersu or open if already installed ! and grant permisson like this
11. supersu will automatically install su binary (need internet connection)! just grant the permisson and let the supersu uninstall Chinese superuser
Your device is now rooted ,you can also apply this method on other chiness or spreadtrum devices ! it's safe
if you want to root your other devices then just pm me, i will tell you
thank you very much
[APP][ROOT] Android 4.1.2 Rooting Universal Method
This method is single for rooting your mobile!
[install]
1. Download Root Explorer [Google Play]
2. Download Root Master
3. Unpack and install Root Master on your PC
4. Install drivers of your mobile
5. Run RootMaster and press first button on first screen
6. After this click the center button on all windows
7. You mobile is rooted - Reboot your mobile
8. Close the RootMaster
9. Install Root Explorer and delete superuser.apk
10. This release of superuser.apk is not english
11. Delete or replace your superuser.apk in /system/app
12. Unpack Superuser.apk from zip and copy to /system/app folder
13. Reply yes to replace your apk Superuser.apk
14. If you delete superuser.apk reinstall Only superuser from Zip
Root Master Download
http://www.4shared.com/rar/hfs9oani/rootmaster.html
Superuser 3.1.3 Free
http://www.4shared.com/zip/KbSjKbGD/Superuser-313-arm-signed.html
Enjoy.....
Br-anabhi
XDA
Source : anabhi - XDA Developers
The Following User Says Thank You to anabhi For This Useful Post:
Old 01-29-2014, 14:04   #14 (permalink)
Member: 1036150
Thanks Meter: 10
Micromax a62 hard reset done
MICROMAX A62 HARD RESET DONE
phone must be on open Android Multi Tools
connect usb cable than pres 5.
Old 03-09-2014, 10:59   #15 (permalink)
Member: 2143734
hi. i have followed the procedure as mentioned, but when i press 8 ; it says < waiting for device >. but whn i redo the same n press 1 i shows device connected , after then when i press 8 it shows < waiting for device >
how long does it shows like that
i waited for long time but nothing happened.
Pls help me
Page generated in 0.68518 seconds with 7 queries
