Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 01-25-2013, 14:13   #1 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
Micromax a65 hard reset [guide]
Press and hold
power and volume up
for 10 sec
then press power for android hiden menu
select factory reset form list then press power for select
enjoy
for
hang
pattern unlock
The Following User Says Thank You to b12345 For This Useful Post:
Old 07-26-2013, 11:19   #2 (permalink)
Member: 912556
Thanks Meter: 25
volume up,press on power button then few minut wipe data factory reset
100% solution i practical
Old 07-28-2013, 14:43   #3 (permalink)
Member: 1515277
Thanks Meter: 2
minut wipe what??????????????????
Old 08-16-2013, 10:44   #4 (permalink)
Member: 1514527
Press and hold
power and volume up
for 10 sec
enjoy
for
hang
pattern unlock
yes good thankssssssssssss
Old 11-04-2013, 11:45   #5 (permalink)
Member: 1301266
Press and hold
power and volume up
for 10 sec
enjoy
for
hang
pattern unlock
Old 11-13-2013, 14:45   #6 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Old 12-14-2013, 15:55   #7 (permalink)
Member: 2084625
Originally Posted by pradeepmobile View Post
Press and hold
power and volume up
for 10 sec
enjoy
for
hang
pattern unlock
plz hlp me unlock my micromax a65 phn...evn this is nt wrkng
Old 12-16-2013, 09:13   #8 (permalink)
chinnivardan's Avatar
Member: 892484
Sonork: not using
Thanks Meter: 916
Press and hold
power and volume up for 10 sec
then press vol up key to see android hiden menu
don't press vol up again
go to wipe with vol down key
now all is done
The Following User Says Thank You to chinnivardan For This Useful Post:
Old 01-10-2014, 09:53   #9 (permalink)
Crazy Poster
Member: 1780708
Sonork: 62645
Thanks Meter: 7
Press and hold
power and volume up
for 10 sec
enjoy
for
pattern unlock
100 % tested
Old 01-10-2014, 10:20   #10 (permalink)
Member: 90733
Thanks Meter: 39
Touch pad senser problem
If this type of set have touch pad senser problem then which method should be applied (Replaced the senser from the other board)
Regards
Old 01-22-2014, 12:42   #11 (permalink)
Member: 1612781
Thanks Meter: 13
http://www.hard-reset.in/micromax-a65-hard-reset.html
Old 01-24-2014, 19:22   #12 (permalink)
Member: 1822765
Sonork: Ugoboy
Thanks Meter: 5
just format with dragon its spd 8810 android
Old 02-25-2014, 11:44   #13 (permalink)
Member: 1407021
Sonork: 7239
gooooood job nice work
Old 04-01-2014, 08:23   #14 (permalink)
sachin.mishra's Avatar
Member: 1856209
Sonork: 100.1626211
Thanks Meter: 44
New method..... Using fast boot..
MICROMAX A65 SPD 8810/6820 PATTERN/RESET GMAIL
TRY THIS METHOD
POWER OFF MOBILE
THEN PRESS VOLUME '-' & POWER KEY AT SAME TIME FOR BEING THE DEVICE IN FASTBOOT MODE.. REMEMBER ALL DRIVERS ARE TAKEN NO YELLOW ICON IN DEVICE MANAGER
NOW USE ANDROID MULTI TOOL
1- TYPE '7' FOR CHECKING DEVICE CONNECTION
2- NOW '8' FOR WIPING USER/CACHE DATA
3- PRESS '9' TO EXIT FASTBOOT MODE TO NORMAL...
NOW YOU ARE DONE......
PRESS THANKS IF IT WORKS FOR YOU..
B.R
sachin.mishra
The Following User Says Thank You to sachin.mishra For This Useful Post:
Old 04-02-2014, 06:26   #15 (permalink)
Member: 1581546
pankaj gupta
this is the best solution, thanks bro
Page generated in 0.19939 seconds with 8 queries
