Micromax General Micromax phones discussion, firmwares, solution, root, help |
01-18-2014, 15:12 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | 1. remove square box from folder name (change folder name chinese to english language) 2. use thick & original usb cable 3. use usb cable at back port of pc & then post result |
02-03-2014, 15:21 | #6 (permalink) |
No Life Poster Join Date: Apr 2013 Location: India
Member: 1910515 Status: Offline Thanks Meter: 289 | Please try this method and check your android driver http://forum.gsmhosting.com/vbb/f811...asher-1732510/ |
02-05-2014, 17:47 | #7 (permalink) |
Freak Poster Join Date: Mar 2006 Location: india
Member: 239231 Status: Offline Sonork: 100.1615723 Thanks Meter: 110 | i m having 2 pc of micromax a67 1 set is pattern locked problem starts when i searched forum some says its mtk cpu n some says its spreadtrum now when i insert normal cable phn does not detect n whn i insert modified cable which we use for spd cpu the phn swicth off automatically where is the problem does any 1 has the solution. n the 2nd phone is dead n never detects.... helpp.... REGARDS |
02-08-2014, 06:32 | #9 (permalink) |
Member: 239231 Status: Offline Sonork: 100.1615723 Thanks Meter: 110 | mr.nitin thx for reply but as i wrote i use modified cable in which 2&3 r d+&d- n 5 gnd n we short 4num with 5 n connect so phn which has spd cpu can detect automatically but this a67 goes dead whn inserted if u use other type of cable plz post the image REGARDS |
02-08-2014, 06:48 | #10 (permalink) | |
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | Quote:
if not solve, then find boot key & short it to gnd & flash your phone here is sample of micromax a72 boot key | |
03-12-2015, 17:53 | #13 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: TELANGANA
Member: 1175976 Status: Offline Sonork: dgr Thanks Meter: 38 | Quote:
