Micromax General Micromax phones discussion, firmwares, solution, root, help |
05-12-2014, 15:48 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 59 | Micromax a67 flashing Procedure needed. 1.Can i set pinout with Gpg Dragon Box as the phone is bricked and no more port deteted with usb cable. 2. Can i flash using og flashtool by setting pinout with gpgdragon without battery with gpg postive and negative cables attached to phone any expert will help me while a67 gives info with gpg dragon by selecting sc8825 ........ what i can do to flash it I have only Gpg Dragon and OG flashtool |
05-12-2014, 16:33 | #2 (permalink) | |
Freak Poster Join Date: Mar 2009
Member: 1001290 Status: Offline Thanks Meter: 81 | Quote:
05-12-2014, 18:06 | #5 (permalink) |
Registered User Join Date: Aug 2009 Location: Bahraich U.P.
Member: 1098797 Status: Offline Thanks Meter: 10 | Micromax a67 flashing full solution hear first modified the cable A67 SW CABEL - Download - 4shared then full flash original tool PA287AN_KMOEB_DM451_Micromax_A67_FOREIGN_V1.1.8 - Download - 4shared - GsmHosting Support SPupgrade Flash tool - Download - 4shared - GsmHosting Support Last edited by moulnisky; 05-19-2014 at 18:56. Reason: No direct links!!! |
05-16-2014, 05:03 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Jul 2011 Location: KANCHEEPURAM, VANDAVASI
Member: 1618492 Status: Offline Sonork: 100.1619678 QQ 2483222717 Thanks Meter: 488 | hi br you have volcano tool Step 1 set pinout using volume down button don't [ remove in your hand ] pinout set completed also http://www.4shared.com/download/YcXU....png?lgfp=3000 http://www.4shared.com/download/A7iG....png?lgfp=3000 step 2 open flash tool file set then run the flash tool [ if flash is started 50% then remove in your hand on volume down ] http://www.4shared.com/download/BurL....png?lgfp=3000 then flash completed in your flash tool [ passed ] found then remove your mobile insert battery and check mobile working fine http://www.4shared.com/download/KB5k....png?lgfp=3000 |
05-19-2014, 18:57 | #10 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
http://forum.gsmhosting.com/vbb/10304280-post5.html BR Alex | |
The Following User Says Thank You to moulnisky For This Useful Post: |
06-25-2014, 06:04 | #12 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Gad-Hinglaj
Member: 1713823 Status: Offline Sonork: sai Thanks Meter: 143 | no need modify cable need phirana or similar box 1 run phirana box in spd tab 2 use 5b cable and -+ box clamp 3 now check port 4 it 100% work |
