Micromax General Micromax phones discussion, firmwares, solution, root, help |
08-22-2015, 20:12 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2015 Location: faridabad(delhi) Age: 33
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | micromax aq4501 1000% sucessfully flashed OG&tested and all type soloution AQ4501 Flashing Procedure Flashing Procedure 2: CAUTIONS I. Flashing & Servicing must be undertaken by qualified personnel only. II. Ensure all work is carried out at an anti-static workstation and that an anti-static wrist strap is worn. III. Use only approved Tools & components as specified in the parts list. IV. Ensure all components, modules, screws, and insulators are correctly re-fitted after servicing and alignment V. Ensure all cables and wires are repositioned correctly if Handset disassembled VI. Electrostatic discharge can easily damage the sensitive components of electronic products. Therefore, Service Centre must adhere the precautions which mentioned above. Note: This This Model Flashing port is locked, so we need to unlock the port before the flashing Port Unlock Procedure: 1. Download Driver Installer here Driver Auto Installer 2.Install Driver Auto Installer 3. Browse my computer for driver software 4. Select driver from Driver Auto Installer according to your sytem configuration. 5. After installing the Driver check the device manager for the connected system devices. 6. Install Java from here-https://java.com/en/download/ According to your PC (configurations (32bit/64bit), download and install java on your PC. 7. Download ADB Driver from here-ADB_Drivers.zip 8. Now Copy ADB_Drivers folder on your desktop and extract it.. 9.Now Open CMD ("Press Windows Button + R"> type "CMD") 10.Now type "cd desktop/ adb_drivers" press enter Thanks B.R Abhay_Rana_Singh |
The Following 3 Users Say Thank You to abhayranasingh For This Useful Post: |
08-22-2015, 20:13 | #2 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | Unlnlocking the Port: 1. Press“+”and“POWER”,then press“+”,select “FASTBOOT” press“—”to confirm 2. Connect the phone. 3. Under the command of CMD type “fastboot devices” and check connected device 4. under the command of CMD type " fastboot oem unlock " --------fastboot OEM unlock, connect USB cable, see the details on the phone, press "+" button to confirm. 5. CMD input "fastBoot -w", press the Enter key, unlock the phone successfully.. After unlocking the port > disconnect phone> on power OFF condition> Flash phone. Now Handset Port is unlocked, so go ahead for flashing procedure 1.USB Drivers Installation Step1: Ensure the battery level is above 50% charged Step2: Turn OFF the phone Step3:install the drivers required for flashing Run Driver EXE file Click on Next Please wait for driver’s installation Below screen may appear, please select Install this driver software anyway please select Install this driver software anyway every time... Thanks B.R Abhay_Rana_Singh Last edited by Deepesh Sharma; 05-08-2017 at 05:07. Reason: remove use less image |
The Following 6 Users Say Thank You to abhayranasingh For This Useful Post: |
08-22-2015, 20:13 | #3 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | 2. Flashing Procedure: Latest Software must available in system and extract the software file Open Flash tool SP_Flash_Tool_v5.1352.01 or or latest folder and run Flash_tool.exe 3. click scat-loading Below screen may appear, please wait till processing complete Caution: Don’t select other options, Handset may dead with below Mota SIU Like Format All + Download Note: If handset flashing not succeeded with with Firmware upgrade Please try ,download only option Select Firmware upgrade only and select on Download button I. Handset must in switch Off condition II. Insert battery III. Connect USB data cable 3 After flashing the phone > Lock After flashing the phone > Lock the port again. If we need to write IMEI > do it before locking the port. port locking procedure 1. Press“+”and“POWER” ,then press“+”,select “FASTBOOT” press“ —”to confirm 2. Follow the same steps above to enter in CMD. 3. Connect the phone 4. Under the command of CMD type "FastBoot oem lock" ----------------------------------------------------------------fastboot OEM unlock, connect USB cable, press "+" button to confirm. 5. Disconnect the phone. Note: After locking> try to flash the phone. The phone should not get flashed.... Thanks B.R Abhay_Rana_Singh |
The Following 8 Users Say Thank You to abhayranasingh For This Useful Post: |
05-15-2016, 18:01 | #13 (permalink) |
Insane Poster Join Date: May 2015 Location: delhi
Member: 2399967 Status: Offline Thanks Meter: 13 | Aq4501 flashind done bro i flash micromax aq4501 Micromax_AQ4501_V3_23.03.15 (lollipop Version)_(by_xdafirmware.com).zip this version mobile dead but i used sp tool new version set is on proper work |
The Following User Says Thank You to shivampal For This Useful Post: |
07-13-2016, 14:54 | #14 (permalink) |
Junior Member Join Date: Dec 2008
Member: 914676 Status: Offline Thanks Meter: 1 | THANXXXXX i tried many ways but at last i flashed with latest sp tool with the same lollipop firmware. AND ITS ON.......working fine now |
The Following User Says Thank You to SUNNY1977 For This Useful Post: |
07-16-2016, 08:30 | #15 (permalink) |
Junior Member Join Date: Sep 2011 Location: Pune
Member: 1646700 Status: Offline Sonork: 7588191410 Thanks Meter: 4 | hey friends i tried to flash my canvas aq4501 but after flashing it became dead. I reflashed it bt still no luck. Mobile gets flashe 100% bt still powering up. please provide me some solution. |
The Following 2 Users Say Thank You to prashantmane92 For This Useful Post: |
