Micromax General Micromax phones discussion, firmwares, solution, root, help |
04-28-2016, 08:26 | #48 (permalink) |
Crazy Poster Join Date: Oct 2010 Location: mumbai,maharhastra
Member: 1414382 Status: Offline Sonork: bablu Thanks Meter: 9 | Micromax D321 | sineshgsm there is ur link |
05-17-2016, 12:48 | #53 (permalink) |
No Life Poster Join Date: Jul 2010 Location: chennai, india
Member: 1354113 Status: Offline Thanks Meter: 669 | d321 wrong flash r dead solution short kcolo+gnd after connect usb press vol+vol- flash use this file:https://docs.google.com/uc?id=0B83Hm...ldCcFU1aWRYcWs 100% tested file after flash disconnect kcolo+gnd hit press only thank button |
06-09-2016, 13:47 | #54 (permalink) |
Freak Poster Join Date: Jul 2013 Location: kerala.cochin16 Age: 33
Member: 1985008 Status: Offline Thanks Meter: 70 | d321 100% done after flash dead just short kcolo point and kcolo1 point and ground (near volume keys) then connect and try flash this file https://docs.google.com/uc?id=0B83Hm...ldCcFU1aWRYcWs 1000% iam also check this..... pls thx button click |
06-28-2016, 16:21 | #56 (permalink) | |
Banned Join Date: Dec 2015 Location: Temp@
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Quote:
Firemware Link : Micromax_Bolt D321 Software 'V2_09.07.15' New Hardware_SW_V12_HW_V1.1_06072015.zip | |
07-06-2016, 11:02 | #57 (permalink) |
Crazy Poster Join Date: Dec 2008
Member: 928107 Status: Offline Sonork: jeeva Thanks Meter: 7 | micromax D321 flashing with wrong firmware dead. Mobile detect as mtk usb in device manager. while flashing with different firmware its showing BROM ERROR: S_STORAGE_NOT_MATTCH(3183). tried with the following firmares. Micromax_D321_V1_20.01.15 Micromax_D321_V2_09.07.15 MMX_D321_SW_V12_HW_V1.1_06072015 MT6572__Micromax__Micromax D321__D321__4.4.2__ALPS.KK1.MP7.V1 but not use showing error. an soution pls. |
07-11-2016, 04:11 | #58 (permalink) | |
2. Press & hold the power key and do the flashing. 3. After flashing, remove jumper wire as added. 4. Power on the handset. It will work properly. 6. Congrats Its Done!! Phone Is Alive... The Point IMAGE Below In This Picture : Note: Don’t forget to remove jumper wire from volume up key after flashing. Tested BY Me In Most Phones Which Have Dead After Flash And Not Connected In Pc..[/B] | |
07-11-2016, 08:46 | #60 (permalink) |
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Dear Friend, Try TO Flash Ur Phone With This Firemware... I Hope Ur Problem Solved After Flashing With This Firemware... Micromax Bolt D321 Software 'V2_09.07.15' New Hardware HW: V1.1 & SW V12 Firemware Here : Firemware Link : Micromax_Bolt D321 Software 'V2_09.07.15' New Hardware_SW_V12_HW_V1.1_06072015.zip Thank U |
