Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 04-17-2016, 07:00   #46 (permalink)
Member: 2245796
Sonork: 100.1604561
Thanks Meter: 20
Format plus download and set ok
Old 04-19-2016, 05:43   #47 (permalink)
Member: 2429257
Thanks Meter: 14
i also need
micromax d321 s/w v12 flash file
Old 04-28-2016, 08:26   #48 (permalink)
Crazy Poster
Member: 1414382
Sonork: bablu
Thanks Meter: 9
Micromax D321 | sineshgsm there is ur link
Old 04-28-2016, 08:46   #49 (permalink)
Member: 1354113
Thanks Meter: 669
d321 firmware:https://docs.google.com/uc?id=0BztcB...XlzNUIxajFhQW8
https://drive.google.com/uc?id=0B9-U...ms5YkxhdTBiQVE
Old 05-03-2016, 06:11   #50 (permalink)
Member: 1480905
Thanks Meter: 25
Dear brother mmx d321 dead boot detect near vol + and vol - kolo solder 2 point with gnd succes
Old 05-04-2016, 06:05   #51 (permalink)
musfiqur rahman's Avatar
Member: 1482831
Thanks Meter: 29
short kcolo and ground then conect usb for Mtk usb
Old 05-17-2016, 10:15   #52 (permalink)
Member: 1336481
Sonork: love
Originally Posted by Rajendra gupta View Post
Bro
do you solve your problem if not
then conect kcolo(near vol up) to ground then flash with your downloaded file
excellent bro I have done with this method
A big thank you
Old 05-17-2016, 12:48   #53 (permalink)
Member: 1354113
Thanks Meter: 669
d321 wrong flash r dead solution
short kcolo+gnd after connect usb press vol+vol-
flash use this file:https://docs.google.com/uc?id=0B83Hm...ldCcFU1aWRYcWs 100% tested file
after flash disconnect kcolo+gnd
hit press only thank button
Old 06-09-2016, 13:47   #54 (permalink)
Member: 1985008
Thanks Meter: 70
Arrow d321 100% done after flash dead
just short kcolo point and kcolo1 point and ground (near volume keys)
then connect and try flash this file
1000% iam also check this.....
pls thx button click
Old 06-21-2016, 12:58   #55 (permalink)
Member: 2587833
Sonork: family
micromax d321 HW ver V1.1 SW ver V12 flash file link...
Old 06-28-2016, 16:21   #56 (permalink)
Member: 2508657
Sonork: 100.1623070
Thanks Meter: 380
Micromax Bolt D321 Software 'V2_09.07.15' New Hardware HW: V1.1 & SW V12 Firemware Here :
Firemware Link : Micromax_Bolt D321 Software 'V2_09.07.15' New Hardware_SW_V12_HW_V1.1_06072015.zip
Old 07-06-2016, 11:02   #57 (permalink)
Crazy Poster
Member: 928107
Sonork: jeeva
Thanks Meter: 7
micromax D321 flashing with wrong firmware dead. Mobile detect as mtk usb in device manager. while flashing with different firmware its showing BROM ERROR: S_STORAGE_NOT_MATTCH(3183).
tried with the following firmares.
Micromax_D321_V1_20.01.15
Micromax_D321_V2_09.07.15
MMX_D321_SW_V12_HW_V1.1_06072015
MT6572__Micromax__Micromax D321__D321__4.4.2__ALPS.KK1.MP7.V1
but not use showing error. an soution pls.
Old 07-11-2016, 04:11   #58 (permalink)
Member: 2508657
Sonork: 100.1623070
Thanks Meter: 380
1. Connect a jumper wire from volume up key to ground as shown in below picture.
2. Press & hold the power key and do the flashing.
3. After flashing, remove jumper wire as added.
4. Power on the handset. It will work properly.
6. Congrats Its Done!! Phone Is Alive...
The Point IMAGE Below In This Picture :
Note: Don’t forget to remove jumper wire from volume up key after flashing.
Tested BY Me In Most Phones Which Have Dead After Flash And Not Connected In Pc..
[/B]
Old 07-11-2016, 08:32   #59 (permalink)
Member: 2506022
micromax d321 after flash dead boot cable connect flash ok but set dead
Old 07-11-2016, 08:46   #60 (permalink)
Member: 2508657
Sonork: 100.1623070
Thanks Meter: 380
Dear Friend,
Try TO Flash Ur Phone With This Firemware... I Hope Ur Problem Solved After Flashing With This Firemware...
Thank U
Page generated in 0.18460 seconds with 8 queries
