Micromax General Micromax phones discussion, firmwares, solution, root, help |
07-11-2016, 05:37 | #2 (permalink) | |
Banned Join Date: Dec 2015 Location: Temp@
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Quote:
Why Use CWM Recovery??? Use Full Factory Firemware For Solved Ur Problem.. There Is Link : LLDEB02_PreCS1.1.27.2_T28C0603_fastbootdownload.zi p Its Fastoot Rom Put Ur Phone In Fastboot Mode And Solved Ur Problem.. Thanks.. | |
The Following User Says Thank You to .::Advance::. For This Useful Post: |
07-13-2016, 07:18 | #3 (permalink) |
Insane Poster Join Date: Jul 2016 Location: Pakistan Bannu Age: 29
Member: 2595796 Status: Offline Thanks Meter: 2 | Dear Friend, Why Use CWM Recovery??? Use Full Factory Firemware For Solved Ur Problem.. Its Fastoot Rom Put Ur Phone In Fastboot Mode And Solved Ur Problem.. Thanks.... Thank You For Reply I want recovery for that purpose so I can install custom ROM ...and also flash able zip files |
07-13-2016, 08:11 | #5 (permalink) | |
Freak Poster Join Date: Jul 2015 Location: Bangladesh
Member: 2424275 Status: Offline Sonork: 100.1625469 Thanks Meter: 68 | Quote:
The Following User Says Thank You to Kashembd For This Useful Post: |
07-13-2016, 23:06 | #7 (permalink) |
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Dear Friend There is no CWM Recovery File For E455 Can U Explain Ur Phone Problem Here?? What Is Ur Phone Problem??? WHY U Need CWM Recovery?? Explian Here Plz Thank U |
07-14-2016, 07:41 | #8 (permalink) |
Member: 2595796 Status: Offline Thanks Meter: 2 | Dear Friend There is no CWM Recovery File For E455 Can U Explain Ur Phone Problem Here?? What Is Ur Phone Problem??? WHY U Need CWM Recovery?? Explian Here Plz Thank U : I was trying to root my phone .. Rooting was successfully done but now the problem is when ever I lock the screen phone restart it self. Again and again. If some app running in background just like music app phone is 100% OK. I need recovery for that purpose so I can clear wipe /cache . |
07-15-2016, 00:07 | #9 (permalink) | |
U Can Clear Wipe/Cache. 1. Put Ur Phone In Recovery Mode Using This Combination Keys.. 2. Afterewards press and hold Volume Up + Volume Down + Power button simultaneously for about 5 seconds. 3. You can release held keys when you see menu on your screen. 4. Then press Volume Up in order to select option "Recovery". 5. Then use the Volume Down to choose "wipe cache particition", and then push the Power button to confirm. Thank U. | |
07-15-2016, 10:52 | #11 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | Quote:
s/w mmx_e455_sw_v16_hw_v1.0_25082015 i flashed with u r ver aftr flash no network n while i m trying to search network in setting error error msg is error while searching for network and change preferred network type thn error unfortunately phone has stopped...... plz help | |
07-16-2016, 11:15 | #13 (permalink) | |
If Problem Not Solved Then U Had To Flash Ur Phone With Firemware Which I Mention In Upper Posts.. After Flash All Everything Is Reset And UR Phone Is Fresh Then Dont Root Ur Phone SomeTime Root Gonna Kill Phone Thank U.. | |
07-16-2016, 13:26 | #14 (permalink) |
Member: 2595796 Status: Offline Thanks Meter: 2 | If u ever find CWM recovery file for this phone plz share...so I can fully flesh the software and every system file fully fresh. And remove the existing software. |
07-16-2016, 16:27 | #15 (permalink) | |
May I Think There Is No CWM Recovery Of E455.. But I Am Trying.. | |
