Micromax General Micromax phones discussion, firmwares, solution, root, help |
02-17-2014, 05:22 | #17 (permalink) |
Insane Poster Join Date: Jan 2008 Location: punjab (india)
Member: 691630 Status: Offline Thanks Meter: 13 | Follow some simple step to Hard Reset or Factory Wipe of your Tablet:- 1.)First of all Switch Off your funbook. 2.)Now,push menu switch,power switch and volume up key together. 3.)Hold this keys for 10 seconds. 4.)After doing this Funbook will be sitched on with Android logo recovery screen. 5.)Doing this recovery menu will appear. 6.)Use volume up switch to select the options. 7.)Select Factory Wipe option from recovery menu. 8.)Use power button to execute. 9.)This will restart the FUNBOOK. |
06-03-2014, 13:16 | #20 (permalink) |
Junior Member Join Date: May 2014
Member: 2179633 Status: Offline Thanks Meter: 2 | Some of you might not go to this screen, rather a dead android, in this case: on adb write the command: adb reboot bootloader this should connect your phone to be flashed using flashtool RKBatchTool |
04-10-2015, 06:48 | #22 (permalink) |
Junior Member Join Date: Mar 2008 Location: Mumbai
Member: 715867 Status: Offline Thanks Meter: 3 | i m having problems in 3rd option when i select 3rd option then the green option is not getting clicked as soon as i click 3rd option it gets switched off and the problem gmail lock remains |
