micromax funbook talk hang on logo I have got micromax funbook talk when power on it hangs on logo .. there is only power button .. no home and volume keys .. need help |
try to reflash your funbook tab, find your firmware here http://forum.gsmhosting.com/vbb/f811...hread-1624105/ Br, azam |
it is micromax p360 .. hang on logo need tool as well firmware and procedure |
Br, azam |
I have downloaded Livesuit and image file s205_NSD(DS)_1.0.3_130301.img Now how to flash this tab .. need procedure please |
bro but how to connect.......? |
just download flashing guide from here & follow step by step surely u will get success. Br, azam |
the tab with only power button ... how to connect it .. need help |
P360 : Funbook talk series,Flashing With B type & Data cable-3 both,Select img file in tool,press start,Continues press & hold 'Home' key on tab and connect cable,drivers automatic install,then press Yes-Yes and software will start,Battery should be >50% always. Note : Ignore 'Device not found' error in tool,never press OK. BR Alex |
Give another link Not Found The requested URL /index.php was not found on this server. |
micromax p350 - Download - 4shared http://i1291.photobucket.com/albums/...ps6666ce33.png tested solution topic closed |
Continues press & hold 'Home' key on tab and connect cable,drivers automatic install,then press Yes-Yes and software will start |
does not process process is hold down and insert usb then press power flashing will be start |
