Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 06-12-2013, 07:08   #1 (permalink)
Member: 772651
Thanks Meter: 1,694
micromax funbook talk hang on logo
I have got micromax funbook talk when power on it hangs on logo ..
there is only power button .. no home and volume keys ..
need help
Old 06-12-2013, 08:09   #2 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
try to reflash your funbook tab, find your firmware here http://forum.gsmhosting.com/vbb/f811...hread-1624105/
Br,
azam
Old 06-12-2013, 12:28   #3 (permalink)
Member: 772651
Thanks Meter: 1,694
it is micromax p360 .. hang on logo
need tool as well firmware and procedure
Old 06-12-2013, 12:34   #4 (permalink)
Member: 505794
Thanks Meter: 2,266
Go here for Micromax P360.
Br,
azam
Old 06-13-2013, 07:46   #5 (permalink)
Member: 772651
Thanks Meter: 1,694
I have downloaded Livesuit and image file s205_NSD(DS)_1.0.3_130301.img
Now how to flash this tab .. need procedure please
Old 06-13-2013, 08:05   #6 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,052
you can follow the same procedure shown in the flashing guide of the P350
download it here
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 06-13-2013, 09:11   #7 (permalink)
Member: 1323417
Sonork: 650150323
Thanks Meter: 61
bro but how to connect.......?
Old 06-13-2013, 09:31   #8 (permalink)
Member: 505794
Thanks Meter: 2,266
what do u mean by how to connect?
just download flashing guide from here & follow step by step surely u will get success.
Br,
azam
Old 06-13-2013, 13:16   #9 (permalink)
Member: 772651
Thanks Meter: 1,694
Br,
azam
brother I know about this guide .. this guide is for those tab which have volume keys .. but P360 have only power button
the tab with only power button ... how to connect it .. need help
Old 06-13-2013, 15:42   #10 (permalink)
moulnisky's Avatar
Member: 947561
P360 : Funbook talk series,Flashing With B type & Data cable-3 both,Select img file in tool,press start,Continues press & hold
'Home' key on tab and connect cable,drivers automatic install,then press Yes-Yes and software will start,Battery should be >50% always.
Note : Ignore 'Device not found' error in tool,never press OK.
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 03-01-2014, 05:47   #11 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 228
Br,
azam
Give another link
Not Found
The requested URL /index.php was not found on this server.
Old 03-01-2014, 08:39   #12 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Originally Posted by Maninder_111 View Post
Give another link
Not Found
NEW LINK DOWNLOAD HERE - Welcome to the ./downloads/Micromax/00_P Serie/P360/ folder of the support area for your service center
Old 05-22-2014, 11:47   #13 (permalink)
Member: 1846157
Thanks Meter: 25
micromax p350 - Download - 4shared
tested solution
topic closed
Old 05-24-2014, 06:06   #14 (permalink)
billa2008's Avatar
Member: 687128
Thanks Meter: 261
Old 05-25-2014, 07:43   #15 (permalink)
Member: 1846157
Thanks Meter: 25
does not process process is hold down and insert usb then press power flashing will be start
Page generated in 0.23161 seconds with 8 queries
