Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-07-2016, 21:59 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Hello how I see there is many users that have Q415 google acount or FRP pb after FW its solution 1. Go tred that want write google acount 2. Press and holed @ in keyboard 3. Will open settings tab go there (keynoard Android) 4. Press back then Task Manager (leftmost) 5. At the top of the screen will open serch google there type settings and then from settings do hard reset. PB WILL BE SOLVED |
The Following User Says Thank You to TUN10 For This Useful Post: |
06-27-2016, 18:05 | #10 (permalink) |
Banned Join Date: Dec 2015 Location: Temp@
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Is U Try This FRP Lock Solution: Install adb-setup-1.4.3 Open command prompt Go to adb directory C:\adb> Switch on the phone connect to the PC using USB Cable Now execute the following commands.. Code: adb shell am start -n com.android.settings/.Settings -e :android:show_fragment com.android.settings.LocalePicker Go to Backup and Reset Now Do a factory reset.. Thanks.. |
The Following User Says Thank You to .::Advance::. For This Useful Post: |
