Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 09-14-2010, 08:41   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1619121
micromax x114
i have micromax x114 dead i did try complete format but it does not power on so pls hlep for this logs below
COM3 [VCP0] selected
module v3.17
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 357458002044922
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:5AD7:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25062501:2AEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: LCSH23_08B_PCB01_GPRS_MT6223_S00.LKAEB04_8_5_1_0T0 3G0831_M561.BIN
project-id: LKAEB04.8.5.1.0T03G0831_M561, 00000000
code offset: 00000000
ffs offset/size [01]: 00710000/000F0000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00710000
checking area [00000000]: 00080000-007FFFFF...
ffs/eeprom found near: 00780000
Detected ffs/eeprom address is non-standard: 00780000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00780000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00780000-007FFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 35868800000015
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 31 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-14-2010, 15:26   #2 (permalink)
Member: 771937
Sonork: 100.1605717
if any operation first backup file ,can u do it? if yes reflash it & try to on.
Old 09-14-2010, 15:45   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1619121
no i dont take any backup and flash whith any file from site i do only complete format only
Airtel Micromax MMX3010p ? gsmsikar Infinity-Box 19 10-26-2012 12:22
Micromax 3010 devenderpsingh Micromax 1 10-06-2008 06:37
06 Jun 2008: "MModule" v2.23 Fly-LX610, Fly-M130, Fly-Levis-LV1, Micromax-X1u, ...... zinoubinabil Infinity-Box 23 06-22-2008 19:10
06 Jun 2008: "MModule" v2.23 Fly-LX610, Fly-M130, Fly-Levis-LV1, Micromax-X1u, ...... zinoubinabil GSM News & Updates 1 06-06-2008 11:14
Wanted ZTE-A16, A18, A19, Micromax for test ! InfinitySupport Infinity-Box 38 02-06-2008 16:07
Page generated in 1.28249 seconds with 11 queries
