Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 07-15-2010, 10:09   #1 (permalink)
Member: 772651
micromax x1i auto on and keypad not working solution
micromax x1i auto on and keypad not working solution needed please help
The Following 2 Users Say Thank You to ajit bs For This Useful Post:
Old 07-15-2010, 12:04   #2 (permalink)
mohamedsafi123's Avatar
Member: 170244
clean the keypad or chenge the charging connecter
The Following User Says Thank You to mohamedsafi123 For This Useful Post:
Old 08-12-2010, 04:16   #3 (permalink)
rajakhank3's Avatar
Member: 1042104
any one testet bro pls post result
The Following User Says Thank You to rajakhank3 For This Useful Post:
Old 08-12-2010, 04:31   #4 (permalink)
jignesh269's Avatar
Member: 113243
chance power ic
after using wrong charger problem happen
if u r phone contain 6223 cpu then change cpu
Old 08-12-2010, 05:07   #5 (permalink)
Member: 619199
i have already 4 set with same problem i remove keypad sticker i remove charging connector problem still same ...........
The Following User Says Thank You to imran87132 For This Useful Post:
Old 04-22-2011, 11:26   #6 (permalink)
Member: 1552639
Sonork: mitesh
micromax x1i keypad 2580 not work............................................
Old 04-22-2011, 16:57   #7 (permalink)
murari-GSM's Avatar
Member: 1538128
Sonork: 100.1613105
reboll cpu and cheng power ic
Old 05-25-2011, 08:48   #8 (permalink)
Member: 1520532
Sonork: 062202073
i need micromax x1i circuit diagram pls ...
Old 08-05-2011, 04:23   #9 (permalink)
Member: 1627248
micromax x 211 auto switch on and keypad not working
plz help me
Old 08-26-2011, 15:42   #10 (permalink)
Member: 1624219
micromax x1i hanging problem plz help me
Old 08-27-2011, 03:38   #11 (permalink)
charan orissa's Avatar
Member: 1524542
Sonork: 100.1607125
re hot or change cpu problem solved
Old 08-27-2011, 16:25   #12 (permalink)
Member: 1482984
try new cpu cheng ,problem solw 100%
Old 08-28-2011, 17:38   #13 (permalink)
ankit9090117706's Avatar
Member: 1291109
Sonork: 100.1607039
rehot cpu problem solved
Old 08-28-2011, 18:33   #14 (permalink)
Member: 1524542
Sonork: 100.1607125
Arrow micromax x1i
not to be rehot
change cpu or reball problem solved
The Following User Says Thank You to charan orissa For This Useful Post:
Old 09-12-2011, 08:47   #15 (permalink)
balajiinfocom's Avatar
Member: 1342188
Sonork: 100.1607654
remove lcd and re connect on pcb tested solution
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.90824 seconds with 11 queries
