Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-18-2014, 06:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Heaven Age: 35
Member: 2141811 Status: Offline Thanks Meter: 38 | Micromax x325 Problem I hv a Micromax X325 Mobile, which is now shutdown and didn't switch on and before switch off it has 100% charge. Then I remove the battery and then I put it back, it was turned on. Later it again switched off. What should I do? I think it need Flash. Plz Guyz Help me.... Thanx in advance |
03-18-2014, 07:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | It don't need flash. Check the voltage at the output of power ic. If it is less than 2v, then u have to check the board short. Possible solutions 1 first of all clean the mb completely and then try. 2 if not solve try the direct vbat jumpering from the output to input. |
The Following User Says Thank You to chandanps18 For This Useful Post: |
03-18-2014, 07:19 | #3 (permalink) |
Member: 2141811 Status: Offline Thanks Meter: 38 | Nothing problem in the voltage, it automatically switch off. I forget to mention 1 thing that after switch the battery level is low and says Battery Low. When I it turn on, it generate heat???? What's wrong with this???? |
