Micromax General Micromax phones discussion, firmwares, solution, root, help |
08-24-2015, 13:27 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2015 Location: faridabad(delhi) Age: 33
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | Micromax x800 sucessfully flashed tested soloution Micromax X800 flashing Procedure Chapter 9 Firmware Upgrading Guide 9.1 Firmware Upgrading 9.1.1 Install USB driver The maximum downloading speed can be up to 921600bit/s when using USB-Serial cable. The driver need to be installed before using the USB cable. Please keep the USB cable unplugged when installing the driver. Plug the USB cable when installing is completed. And check device manager of the PC. Run the “Flash_tool.exe” of FlashTool_v5.1112.00 Please select “Options”-“COM port”-Choose the port which is same as the one in “Device Manager”. Select “Options”-“Format FAT (DISABLED)…” and please do NOT select “validation”. Please select “Format FAT”. Select “Options”- “Backup and Restore”, then select the “Backup -> Download/format -> Restore”. Click the ”Download Agent” and select the file “MTK-ALLInOne-DA.bin”. Click the “Scatter/config file” and select the “scatTINNO36_11A_GEMINI.txt”. Power off the handset, remove the battery, click “Download”, and connect the cable with handset, then insert the battery, press the power on button, the gray, red, blue, green and gray progress bar shall appear. Then upgrade would be completed when appear “OK”. Backup the data. (gray progress bar) Connect to phone. (red progress bar) Downloading is in process. (blue progress bar) Downloading is completed. B.R Abhay_Rana_Singh Last edited by abhayranasingh; 08-24-2015 at 13:35. |
08-24-2015, 13:45 | #2 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,202 | Description: can’t power on(also upgrade software fail) Root cause: red scroll 100% run completely when upgrade software, the detail as figure 1, also it prove power supply, clock is normal and defective typical issue is focus on CPU or FLASH poor soldering or damage, and maybe software do not fit for hardware. Corrective action: check software fit for hardware whether or not, resolding CPU and FLASH or exchange new CPU and FLASH. 图 1(figure 1) Description: E930 can’t power on (handset is dead when upgrade software.)details as figure 2. Root cause: the power supply and clock both work on as common during upgrade software. The typical defective issue as poor soldering or go to fall, other way as exchange CPU or Flash. Corrective action: re-solder CPU and Flash, or replace them. if you like my post just press onlybutton B.R Abhay_Rana_Singh |
The Following User Says Thank You to abhayranasingh For This Useful Post: |
07-12-2016, 06:41 | #4 (permalink) | |
Banned Join Date: Dec 2015 Location: Temp@
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Quote:
Here IS Micromax X800 Scatter File On Ur Requst Plz Flash Ur Phone Using My Flash-File And Post Sucess Result Here.. Firemware : X800_SW1151.rar Thank U.. | |
