Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax > Micromax Hardware Repair
Old 02-27-2015, 13:29   #1 (permalink)
Member: 1291708
Thanks Meter: 15
mmx a27 usb not recognized solution
i have a mmx a27 with pattern lock, when i connect with usb show usb not recognized, i solderd a cable direct to dp dm and checked for gnd and shorting but was normal. after all these steps no success.
can i connect the handset with rx tx please tell the procedure
Old 03-02-2015, 07:45   #2 (permalink)
sb99sameerkhan's Avatar
Member: 1978625
Sonork: 100.1661449
Thanks Meter: 39
IMG_20150302_120921 - Download - 4shared - Sameer Khan
The Following User Says Thank You to sb99sameerkhan For This Useful Post:
Old 03-02-2015, 07:46   #3 (permalink)
Member: 1978625
Sonork: 100.1661449
Thanks Meter: 39
sam rehmani brother check avery line charging pin try
Old 03-08-2015, 06:18   #4 (permalink)
Member: 1054903
Thanks Meter: 4
remove dp dm diods
REMOVE BOTH DM AND DP PROTECTION DIODES
USE SHORT USB CABLE ( NO MORE THEN 1 METER)
REHOT USB SQURE IC
TRY WITH ANOTHER COMPUTER OR OS (SOME TIMES PC CAUSE PROBLEM)
Page generated in 0.18852 seconds with 9 queries
