Micromax General Micromax phones discussion, firmwares, solution, root, help |
10-09-2014, 11:45 | #1 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2258511 Status: Offline Thanks Meter: 0 | Mount script cannot be created. mount: No such file or directory Please help me... |
10-10-2014, 05:04 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | This problem already arised with me. But I solved it... How do u partition or format ur SD card.... U try it in the phone recovery menu with cwm or twrp. Otherwise u can use partition wizard home edition or easus partition master in ur PC to create such partition format. Note: first create your required partition e.g ext2,ext3,ext4 ..... etc and then create partition for ur local data use... Hope ur problem solved... Hit thanks button if like my post |
10-09-2015, 07:12 | #3 (permalink) | |
Junior Member Join Date: Nov 2009
Member: 1171177 Status: Offline Thanks Meter: 0 | Mount script cannot be created, no such device, stock rom mmx a40 Quote:
10-13-2015, 09:19 | #5 (permalink) | |
Member: 1171177 Status: Offline Thanks Meter: 0 | mount script can not be created Quote:
I flashed my A40 with research download tool. The tool didn't work in win-7 64bit or 32bit I formatted my hdd with winxp 32 bit and then research download + adb all worked like charm. btw I'm still finding a way to solve the link2sd problem. | |
