Micromax General Micromax phones discussion, firmwares, solution, root, help |
08-15-2015, 00:42 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: kanpur Age: 35
Member: 1033905 Status: Offline Sonork: amitsharma Thanks Meter: 892 | Micromax A310 after flash factory mode..FIXED after flash...... here recover solution.. download here small file Dev-Host - Factory mode fix by Pinto.zip - The Ultimate Free File Hosting / File Sharing Service 1. Download and extract all the Files in a folder that's easy to find 2. On ur Phone then connect it to a PC 3. Open cmd to run as administrator 4. type- adb shell 5. Type- Quote: -b fctd normal or fctest system reboot 6.Press Enter 7. Phone will restart automatically, 8. Click "unFactroy Mode.bat" when open cmd screen press Enter, wait for it to finish and then press Enter again, Phone again will restart automatically and return to normal RECOVER DONE.... BRO.. AMIT SHARMA |
The Following 6 Users Say Thank You to amit kanpur For This Useful Post: |
12-07-2015, 06:59 | #3 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1418692 Status: Offline Thanks Meter: 8 | attach the handset with pc through usb cable Extract the adb folder and copy to c:/drive open command prompt. Write following commands cd C:/adb adb devices adb shell fctd -b normal handset will restart automaticaly to normal mode |
The Following User Says Thank You to shadabmnp For This Useful Post: |
12-07-2015, 07:11 | #4 (permalink) |
Member: 1418692 Status: Offline Thanks Meter: 8 | this is a good link factory mode solution - Download - 4shared |
01-31-2016, 06:54 | #5 (permalink) |
Freak Poster Join Date: Apr 2009 Location: salem tamilnadu
Member: 1004553 Status: Offline Sonork: imran007 Thanks Meter: 15 | Dear friends ,I flashed A310 by YGDP TOOL succesfully.But set restarting logo only,Its connecting with fastboot mode only not in ADB mode.Any tricks? |
09-02-2016, 12:44 | #7 (permalink) |
Freak Poster Join Date: May 2013
Member: 1935677 Status: Offline Thanks Meter: 22 | [QUOTE=shadabmnp;11459225]attach the handset with pc through usb cable Extract the adb folder and copy to c:/drive open command prompt. Write following commands cd C:/adb adb devices adb shell fctd -b normal handset will restart automaticaly to normal mode this method not working please give me tested soluion handset attechment list error problem |
12-30-2016, 19:02 | #8 (permalink) |
Insane Poster Join Date: Jul 2007
Member: 554849 Status: Offline Thanks Meter: 24 | the correct method is here 100000000% tested: 1. Download and extract all the Files in a folder that's easy to find 2. On your Phone then connect it to a PC 3. Open cmd to run as administrator 4. type adb shell 5. Type: fctd normal press enter Type: fctest system reboot Press Enter 7. Phone will restart automatically, 8. Click "unFactroy Mode.bat" when open cmd screen press Enter, wait for it to finish and then press Enter again, Phone again will restart automatically and return to normal |
10-10-2017, 15:11 | #12 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2587820 Status: Offline Sonork: [email protected] Thanks Meter: 2 | thanks its working solution |
11-05-2017, 17:38 | #13 (permalink) | ||||
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | Quote:
here uploaded all commnd try but fhon is saame condition pls give mi tested solution | ||||
