Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-12-2013, 11:07 | #7 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | Easy Pinout Search For MTK Cpu Here I Guide You All About Pinout Search(Rx-Tx) For Midiatek(Mtk) Cpu 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2*7-2*9volts. those are tx/rx please note that this method is valid only for MT62xx phones. so please check CPU type first! |
The Following User Says Thank You to unlockers555 For This Useful Post: |
11-30-2013, 08:25 | #14 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 912556 Status: Offline Thanks Meter: 25 | micromax a 27 hard reset 100 % solution.............. press vol down and on 30 second contine.. then fastboot mode logo then android molti tools open press-8 wipe data press -9 exit fastboot mode |
