[Solution] Micromax Boot Mode keys combination X231 no key need to press, with x11i cable. X368 press 1 or green key before connect to flash tool or maui meta,Flashing Cable-X265 X660 volume down key press before insert data cable-3 for sw( Flahing cable-5: SPAMOB1800 can also be used) X283 press 0 no. key before connect X11i flashing cable for maui meta or flashtool.(select USB in comport) X288 : Flashing cable-6, SPAMOB1192 A73 : Both keys home and back, before insert cable, A78 : Volume UP key, before insert cable. X271: Press Green/calling key before insert download cable. X1i reloaded : Data cable-3,press calling/green key before download. X640 : SW with volume Upkey and normal USB X256,X257 : X11i flashing cable, press calling key X275 : normal USB, data cable-3,LSK need to press X335 : Data cable-3, with Calling key X274 : Flashing cable-4,SPAMOB0587,same of Q5fb Q55 Version 13 is available on FTP with name New BT090910 GC200 Flashing : cable is common with GC257 SPAMOB3554(cdma) SPAMOB3555(Gsm) X246 : cable is common with X11i and X550.( Need to press 0 to start, hold and press * key while sw update) X223 Flashing : X11i cable, Green key for downloading X78 : Data cable -3, green key pressing for software update. X450 : SPAMOB6114-Flashing cable-X450, otherwise disconnect Vcc line from SPAMOB1800 cable and use as alternative flashing cable. Q85: Data Cable-3,RSK need to press. Q36 : Use Data cable-2 for Flashing & IMEI, Press & hold 'Space' key before insert cable for flashing or IMEI. X312 Flashing : X11i flashing cable , 0 key need to press X259 : X11i Flashing cable ,Green/calling key need to press. X210+ Flashing : Calling key + Normal USB cable X445 Flashing : X11i Flashing cable with center key pressing. X1i Xtra : X11i cable for Flashing, IMEI with X290 IMEI cable. X45 Flashing : X11i Flashing cable,no key need to press X44 Flashing :X11i Flashing cable ,RSK need to press(data cable-3 with 0 key) A50 : Data Cable-3,Volume down key A80 Flashing : X11i cable, direct software, without pressing any key X277 : Flashing cable of X11i, LSK need to press for flashing. X234 :X11i Flashing cable, * (Star)key need to press A84 Flashing : Copy SW in blank memory card, insert in phone, switch on with pressing Volume UP + Down keys together, SW starts automatically. X294 Flashing : With X11i cable, LSK key need to press while flashing. A52 Flashing cable X11i cable. X102/X274/X490 : Flashing Cable -4 : SPAMOB0587 X276 Flashing : Data cable 3 with 1 key press. X291 : cable is common with X11i and X550.( Need to press * to start, hold and press * key while sw update) C190 : Data Cable-2 X268 : Flash with X11i cable, # key need to press before connecting cable. Q34 :X11i Flashing cable ,Call key need to press A45 : Flashing Cable-7 , SPAMOB1951 X50 : Data cable-3, LSK Key X331 : X11i Flashing cable, Press Calling key for downloading. A56 : THROUGH MMC ,PRESS UP ARROE KEY+VOL UP KEY X275 : LSK Key, X11i Flashing cable X278 : Data Cable-3, Press '1' key before connect cable for Downloading to make USB COM PORT. X292 : X11i cable, no need to press any key while connect with tool A57,A87: Copy and paste SW folder in memory card, extract or wo extract, Volume UP key + Power ON to start download. A84: Copy and paste SW folder in memory card,extracted SW files, VolumeUP+Down+ Power ON key to start download. X293 : Falshing with Data cable--3, No need to press any key for flashing,MTK Flshtool 5.1220. X101,X103 : Flashing with Data cable-2(LSK), IMEI with IMEI CABLE-SPAMOB5760, write IMEI in tool, press write, insert cable in phone w/o battery, then at last insert battery in phone.Sample passed X455(White+Black)SW joint),X1iXtra,: Cable name-Flashing cable-X455 Spreadtrum (SPAMOB5761) X279 SW(Joint Black+white),A73IMEI(no joint),X455 IMEI(NO JOINT),X292SW(Black+white),X324(SW Bl+Wh joint): MSTAR cable(SPAMOB5762) X331i(6250A) : Select .cfg file not Scat.LSK KEY need to press before insert Data cable-3. X456 : No need to press any key for flashing, with Data cable-3 And X11i Flashing cable(B type cable) X293: Falshing with Data cable--3 or X11i flashing cable, No need to press any key for flashing,MTK Flshtool 5.1120,Select cfg file in place of scat file. X234C : 'Music' key need to press before connect to DATA CABLE-3 or X11i Flashing cable for Flashing. P350 :Press Vol+ and on/off switch inset the data cable hold the Vol+ & through On/off switch give the puls X446,X456 :With data cable-3 select .cfg file not scat file A101 : Plug in data cable-3 while pressing the volume + key in the phone A110 : Plug in data cable-3, For IMEI , tool version is 6.1204 maui meta only A90S,A90 : X11i cable X234+ : Use X11i cable for Flashing, Press '1' key before insert cable for flashing or IMEI write. A25 : B Type Micro USB (SPAMOB3592) , no shortcut key, insert cable directly for software download. X210+ : Flashing with Data cable-2, shortcut key for COM PORT making is Calling(green) key. X350 : SPAMOB5762,For SW (Bl+white), X269: Select cfg file in place of scatter,X11i flashing cable with Key press LSK X325,X295,X286 : .cfg file in place of scatter file,LSK download key,with X11i cable & data cable-3 both. A65 : Flashing With Data cable-3,Press Side Volume Down key before insert cable. A65 : imei with SPAMOB5761 Q76 : MTK flash tool, With Data cable-3 or B type cable, Center key is download key before connect cable for flashing. X396 : MTK Flash tool, No need to press any download key, with Data cable-3 or B type cable. P600 : Update with normal USB data cable-3, update procedure PDF & IMEI writing doc is available on FTP. After update software, Press RESET button for 5 Second, then switch ON the tab,will take 3-4 minuts to boot first time. Later on, normal use it. A89: B type USB cable (SPAMOB3592), No shortcut key for download( Volume down for Data cable-3) Q23 : Select .hqs file in place of scatter in multiport MTK flash tool, Press LSK(left soft key) before connect to Data cable-3 for flashing. A54 : Software update with Memory card, copy zip software file in card(4GB), insert in phone,Press & Vol Up key+Power ON, apply update from SD card, update start. IMEI tool is same like A57. P550 : B type cable for Flashing, Open tool, select key & image file, press start on tool, press & hold Vol UP key & insert cable, then toggle Power ON key 4-5 times, Software update will automatically start. After finish software, press all 3 side keys together and switch ON, it will reset the tab. Now normal switch on the tab. GC222/GC333 : Use Data cable-3/B type for flashing, press '1' no. key before insert cable for flashing.MTK Flash tool 5.1236 X340 : Normal USB data cable-3 or B type cable.No shortcut download key, Press download and insert cable. X099 : Data cable-3 or B type cable for flashing, MTK Flash tool 5.1136 or latest, Press '2nd calling key' before insert cable for download. X327 : Data cable-3 or B type cable for flashing, MTK Flash tool 5.1136 or latest, Press '2nd calling key' before insert cable for download. A116 : Data cable-3 for Flashing & IMEI,MTK tools,No download shortcut key,direct plug cable for SW or IMEI.Flash tool 3.1312.0.139 A88 : Data cable-3 for Flashing & IMEI,MTK tools,No download shortcut key,direct plug cable for SW or IMEI. P360 : Funbook talk series,Flashing With B type & Data cable-3 both,Select img file in tool,press start,Continues press & hold 'Home' key on tab and connect cable,drivers automatic install,then press Yes-Yes and software will start,Battery should be >50% always. Note : Ignore 'Device not found' error in tool,never press OK. A115 : MTK tools, B type USB cable,X11i flashing cable can be used for Flashing, No download shortcut key,Direct plug cable for Flashing & IMEI. A35/A27 : Run driver file 'DPInst.exe', Normal USB data cable-3 for flashing, Select Pac file,press play/start on tool, press Volume down key on phone(with battery>50%),Connect the cable,installation of drivers takes place automatically. Then software auto start, For IMEI : Open IMEI tool, connect phone with USB & switch ON, check 'DIAG'COM PORT in device manager,Select COM in tool,Write IMEI on tool, press write,IMEI will successfully written. P560 : Flashing thru SD card, Take 4 GB formatted SD card,Format internal storage of Tab too, now copy and paste zip file. Press & hold Power+Volume down key,once tab starts vibrate,release Power key only and hold volume down same, Recovery mode will open on screen. 3rd option,Update from SD card,select file and start update.After success,restart tab. For IMEI : Use A57,A87,A56 same 'Repair 3G tool' with normal data cable. A62/A26 : Use cable SPAMOB5762(short external wires) for Flashing,first insert cable then battery and B-type Normal Micro USB(SPAMOB3592) cable for IMEI. For IMEI : Open IMEI tool, Switch On phone and connect withn B type USB cable(SPAMOB3592), press 'Mode Sel' and 'Normal Mode', write 15 digit IMEI and press 'Write' on tool, will shows green success, means done. A72 : Use MTK super phone Flash tool 3.1244 for flashing, B type normal USB(SPAMOB3592), SN writer for IMEI. X322 : (MT6250 chipset) Data cable-3 for flashing, Press Square key below LSK(left soft key) before insert cable for flashing, Maui meta tool for IMEI writing. A110Q/A88/A86/A92 : Flash tool 3.1312.0.139 or latest, Data cable-3, No shortcut download key for flashing, direct plug in cable, Maui Meta for IMEI. A111 : Paste Software zip file to formatted 4 GB memory card, Press & hold Volume UP key and Power On key, software automatically starts after showing Canvas animation. For IMEI : follow IMEI process given. C260 : SW download version 3.8, Select Chipset QSC1110, Settings: click on 'Auto & extra restore', Browse Software folder, press start download and connect data cable-2,USB cable, drivers installation and software will start. MEID tool given specifically. A51 : Install both drivers .exe files first. Broadcom chipset download tool 'BrcmFlashTool_V2.0.7.0', Follow download procedure given, with battery, charge >50%. IMEI tool specific, Connect phone wothout battery and follow its proceure given. X321 : Use SPAMOB5761 for flashing, Spreadtrum chipset flashing and IMEI method,like X455. A210/A240 : JB 4.2.1,Flash tool 3.1312.0.139 or latest, Data cable-3, No shortcut download key for flashing, direct plug in cable, Maui Meta for IMEI. A113 : JB 4.1.3, Normal USB cable for flashing. Step 1 : Press Volume down+Power key in Off condition, phone will come in download mode for flashing. Step 2 : Open tool EMMC download tool V1.2.4 and click 'Download bootloader' option only. Step 3 : Connect phone with PC and install drivers, Edit Com port number in tool. Step 4 : Extract both zip software folders and copy paste other folders all files in 1 folder with name '593513_8732_WCDMA_V.....zip'. Step 5 : Select path of this folder now in tool and press download, after some time, it will show success, Done. For IMEI re-write in A113 : IMEI tool given separately. X328/X282 : Based on MT6260D chipset, Normal USB cable for flashing, Open tool and select flashing files, Press CSK(center soft key) before connect cable for flashing. Tab P650 : 3G Tab, JB 4.2.1, Based on MT 8389, 1.2GHz Quad core CPU. Open tool , select files, Press Volume down key in off mode and connect normal usb cable for flashing. IMEI Re-write : after flashing, dial *#3646633#*#* and select write IMEI option, edit IMEI manually and save it, restart tab, now check IMEI by *#06# X351/X088/X084/X273 : Based on spreadtrum chipset, SC6531 Normal USB cable for flashing, open tool and select pac file, Press LSK(left soft key) before connect to PC for flashing. IMEI Writing : If not able to make COM PORT, Dial *#64276#, Para set/Debug/Assert/Open and now connect USB cable. |
X263 need boot key help me plz |
hello, Quote:
it have mtk cpu,open phone and find rx-tx do job as you need :) |
i want a75 boot key...:( |
br, azam:) |
There is no boot key for Q50 Do it via RX TX on board WBR Jyoti |
micromax a62 cable pinout |
micromax x351 rxtx cable pinout |
funbook infinity p275 key for download mode |
how to flash micromax x222 and which box dose how to flash micromax x222 and which box dose |
normal mtk flash tool , calibration with maui meta and cetre key for b0ot |
micromax a75 boot key Quote:
vol - key not working :) |
micromax a62 please ? :) |
