[TUTORIAL] How to Flash Micromax A87 Solution inside How to Flash Micromax A87 http://img809.imageshack.us/img809/7404/micromaxa87.jpg FLASH TOOL DOWNLOAD USB DRIVER DOWNLOAD FLASH FILE DOWNLOAD FASTBOOT MANUAL DOWNLOAD Micromax A87 Flashing procedure |
Has anyone tested this solution?? |
yes if anyone tested this file pls tell us so we will try thanks in advance! |
what flash tool you use it for |
A87: Copy and paste SW folder in memory card, extract or wo extract, Volume UP key + Power ON to start download. but how to enter download mode or fastboot mode problem : phone vibrate when switch on |
micromax a87 how to flash ,, vibrate when on .... no responce no display... help me plzzzzzzzzzzzzz |
micromax a87 flash tool needed urgent.............. |
Don't be lazy: use search next tim, please. Welcome to the ./downloads/Micromax/00_A Serie/A87/ folder of the support area for your service center Here whatever you may need for the A87 Micromax BR Alex |
plz any one have tested solution for this mode micromax a87 |
sir micromax a87 only vibrate i try with memory card but not done ( other on set update ok with memory card ) how to flash connect with usb driver not dound common headset driver not ok |
sir if u have on or hang set then it works i have two set one hand and one dead only vibrate hang set done with memory card but dead no |
Plz help me I am new comer in this field, plz help me how to post a message to someone who is online or how to chat in this forum plz plz help |
Micromax A87 Only SD Update Available For This Phone Must Be Powered On. if ur phone not power on try with Fast Tool |
2 Attachment(s) MCX A57,A87 fastboot manual Note: This method is only applicable to: users to upgrade failure, and the mobile phone hold to the boot screen or only find the ADB interface. Step: 1、 Install the battery to the mobile phone; 2、 Hold the volume down key, then press the boot key about 2 seconds, wait for mobile phone to vibration, then loosen the boot key button, but volume down key don't loosen;; 3、 Mobile phone and computer use USB cable connection (keep the volume key press and hold), and then open the 'device manager ", can find "Android Devices'' Android ADB Interface", as the FIG: http://forum.gsmhosting.com/vbb/atta...1&d=1432007034 4、Decompress fastboot.zip, copy the system.img,boot.img,userdata.img&recovery.img files of the software package into the fastboot folder ,then double click ‘download.bat’ and loosen the volume down key, to start writing boot.img, system.img,userdata.img and recovery.img files, write is completed, the computer screen will prompt" Press any key to continue... ' ,as the FIG http://forum.gsmhosting.com/vbb/atta...1&d=1432007039 |
