Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 04-20-2013, 06:15   #1 (permalink)
shuvo007's Avatar
Member: 775086
Sonork: 100.1603609
Thanks Meter: 372
Thumbs up [TUTORIAL] How to Flash Micromax A87 Solution inside
FLASH TOOL
DOWNLOAD
USB DRIVER
DOWNLOAD
FLASH FILE
DOWNLOAD
FASTBOOT MANUAL
DOWNLOAD
Micromax A87 Flashing procedure
The Following 2 Users Say Thank You to shuvo007 For This Useful Post:
Old 04-20-2013, 07:48   #2 (permalink)
faizal313's Avatar
Member: 1019517
Sonork: 100.1614559
Thanks Meter: 102
Has anyone tested this solution??
Old 04-20-2013, 08:02   #3 (permalink)
Member: 1532854
Sonork: 100.1639591
Thanks Meter: 104
yes if anyone tested this file pls tell us so we will try thanks in advance!
Old 04-20-2013, 08:06   #4 (permalink)
Member: 413128
what flash tool you use it for
Old 09-16-2013, 07:05   #5 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 179
A87: Copy and paste SW folder in memory card, extract or wo extract, Volume UP key + Power ON to start download.
but how to enter download mode or fastboot mode
problem : phone vibrate when switch on
Old 02-04-2014, 18:43   #6 (permalink)
Member: 1962746
Sonork: none
Thanks Meter: 25
micromax a87 how to flash ,, vibrate when on .... no responce no display... help me plzzzzzzzzzzzzz
Old 02-04-2014, 18:50   #7 (permalink)
Member: 1962746
Sonork: none
Thanks Meter: 25
micromax a87 flash tool needed urgent..............
Old 02-05-2014, 08:30   #8 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,070
Don't be lazy: use search next tim, please.
Welcome to the ./downloads/Micromax/00_A Serie/A87/ folder of the support area for your service center
Here whatever you may need for the A87 Micromax
Alex
Old 02-05-2014, 12:58   #9 (permalink)
Member: 1962746
Sonork: none
Thanks Meter: 25
plz any one have tested solution for this mode micromax a87
Old 02-09-2014, 11:59   #10 (permalink)
Member: 1181433
Thanks Meter: 6
sir
micromax a87 only vibrate
i try with memory card but not done
( other on set update ok with memory card )
how to flash
connect with usb driver not dound
common headset driver not ok
Old 02-09-2014, 12:19   #11 (permalink)
Member: 1181433
Thanks Meter: 6
sir
if u have on or hang set
then it works
i have two set one hand and one dead only vibrate
hang set done with memory card but dead no
Old 02-09-2014, 12:36   #12 (permalink)
Member: 2103288
Plz help me
I am new comer in this field, plz help me how to post a message to someone who is online or how to chat in this forum plz plz help
Old 02-09-2014, 12:58   #13 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: 100.1650339[OFFLINE]
Thanks Meter: 993
Originally Posted by avinashjindal13 View Post
sir
then it works
do you try to flash it
Micromax A87 Only SD Update Available For This Phone Must Be Powered On.
if ur phone not power on try with Fast Tool
Old 02-09-2014, 13:28   #14 (permalink)
Member: 1181433
Thanks Meter: 6
thanks 4 reply but how to flash
Old 05-19-2015, 04:40   #15 (permalink)
Member: 1642979
Sonork: 100.1613407
Thanks Meter: 179
MCX A57,A87 fastboot manual
Note:
This method is only applicable to: users to upgrade failure, and the mobile phone hold to the boot screen or only find the ADB interface.
Step:
1、 Install the battery to the mobile phone;
2、 Hold the volume down key, then press the boot key about 2 seconds, wait for mobile phone to vibration, then loosen the boot key button, but volume down key don't loosen;;
3、 Mobile phone and computer use USB cable connection (keep the volume key press and hold), and then open the 'device manager ", can find "Android Devices'' Android ADB Interface", as the FIG:
4、Decompress fastboot.zip, copy the system.img,boot.img,userdata.img&recovery.img files of the software package into the fastboot folder ,then double click ‘download.bat’ and loosen the volume down key, to start writing boot.img, system.img,userdata.img and recovery.img files, write is completed, the computer screen will prompt" Press any key to continue... ' ,as the FIG
The Following User Says Thank You to anil.prajapati For This Useful Post:
Page generated in 0.36397 seconds with 8 queries
