Micromax General Micromax phones discussion, firmwares, solution, root, help |
08-26-2015, 17:12 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2015 Location: faridabad(delhi) Age: 33
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,203 | YU(YUREKA) - UNLOCK BOOTLOADER, FLASHING CUSTOM RECOVERY, ROOTING (normal method) YU(YUREKA) - UNLOCK BOOTLOADER, FLASHING CUSTOM RECOVERY, ROOTING (NORMAL AS WELL AS PDANET METHOD) EXPLORE UNLIMITED POSSIBLITIES BY ROOTING YOUR DEVICE METHOD - 1 (NORMAL)ROOTING DOESN'T VOID YOUR YUREKA's WARRENTY INSTRUCTIONS FOR [ 64-Bit ] OFFICIAL STOCK CM12s (LOLLIPOP) Requirements : Laptop or Desktop with windows OS USB Data cable Files Required: adb.zip : DOWNLOAD HERE SuperSU.zip : DOWNLOAD HERE TWRP Recovery :DIRECT LINK ..............OFFICIAL POST CMW Recovery : DIRECT LINK ..............OFFICIAL POST Download adb.zip file and extract it in your PC path C:/ADB now place CWM recovery : "cwm_recovery.img" [or] TWRP recovery : "twrp_recovery.img" in that ADB folder WARNING: -> Unlocking bootloader will erase all your data. So backup your data before unlocking bootloader PROCEDURE : -> Now copy SuperSu.zip in Root of the SDcard in your device -> Now Turn off the device and connect mobile to PC using USB cable -> Now at the top you can see RED led glowing. Once you observe it keep pressing the Volume up rocker button and your device will move to fastboot mode. -> Now navigate to ADB folder c:/ADB -> Now open adb terminal by "shift + right click" and select "open command prompt here" Now follow these steps in adb terminal: Code: fastboot -i 0x1ebf oem unlock NOTE: If U are facing issue like "waiting for device" when U type the command then please follow METHOD 2 Code: fastboot -i 0x1ebf flash recovery cwm_recovery.img [OR] Code: fastboot -i 0x1ebf flash twrp_recovery.img Note : if you download any other custom recovery which is named differently just replace "cwm_recovery.img" to ur recovery name "your_recovery.img" without quotes in above command. Code: fastboot -i 0x1ebf reboot that's it now your bootloader as been unlocked and installed CWM or TWRP custom recovery NOTE: In this stage i suggest you take full nandroid backup which is very very very useful in future and dont delete that backup ever. i always suggest CWM recovery which works on both touch interface as well as device hard keys. TO ROOT YOUR DEVICE -> Place "SuperSu.zip" in your internal or external Sd card -> reboot to recovery and select install zip from storage and browse to the folder where you have downloaded the SuperSu.zip that's it now your device has been rooted For those who are facing Device Detection issue on adb METHOD - 2 (USING PDANET SOFTWARE) . Requirements : Laptop or Desktop with windows OS USB Data cable Files Required: db.zip : DOWNLOAD HERE SuperSU.zip : DOWNLOAD HERE TWRP Recovery :DIRECT LINK ..............OFFICIAL POST CMW Recovery : DIRECT LINK ..............OFFICIAL POST PdaNet mobile app : DOWNLOAD HERE PdaNet PC application : DOWNLOAD HERE Download adb.zip file and extract it in your PC path C:/ADB now place CWM recovery : "cwm_recovery.img" [or] TWRP recovery : "twrp_recovery.img" in that ADB folder WARNING: -> Unlocking bootloader will erase all your data. So backup your data before unlocking bootloader PROCEDURE : -> Download and install PdaNet mobile app : https://play.google.com/store/apps/d...?id=com.pdanet -> enable usb debugging in setting -> Developer options -> Mark ADB debugging and USB debugging -> Install PdaNet software in PC : Download PdaNet+ -> when PdaNet software in PC requested to connect mobile Keep mobile TURN ON and connect it using USB cable. -> it will install the device drivers automatically, if already installed select reinstall option -> Now unplug the device from USB cable -> Now reboot PC as well as mobile -> now keep mobile TURN ON and connect mobile to PC using USB cable -> Now navigate to ADB folder c:/ADB -> Now open adb terminal by "shift + right click" and select "open command prompt here" Now follow these steps in adb terminal: Code: adb devices Code: adb reboot-bootloader Code: fastboot -i 0x1ebf oem unlock Code: fastboot -i 0x1ebf flash recovery cwm_recovery.img [OR] Code: fastboot -i 0x1ebf flash twrp_recovery.img Note : if you download any other custom recovery which is named differently just replace "cwm_recovery.img" to ur recovery name "your_recovery.img" without quotes in above command. Code: fastboot -i 0x1ebf reboot that's it now your bootloader as been unlocked and installed CWM or TWRP custom recovery NOTE: In this stage i suggest you take full nandroid backup which is very very very useful in future and dont delete that backup ever. i always suggest CWM recovery because which works on both touch interface as well as device hard keys TO ROOT YOUR DEVICE -> Place "SuperSU.zip" in your internal or external Sd card ->reboot to recovery and select install zip from storage and browse to the folder where you have downloaded the superuser.zip that's it now your device has been rooted INSTRUCTIONS FOR METHOD - 1 (NORMAL)[ 32 Bit ] OFFICIAL STOCK CM11s (KITKAT) [HIDE] Requirements : Laptop or Desktop with windows OS USB Data cable Files Required: ADB.zip : DOWNLOAD HERE Philz Recovery : DOWNLOAD HERE SuperSU :DOWNLOAD HERE Download ADB zip file and extract it in your PC path C:/ADB now place philz recovery : "recovery_yuphilz.img" in that ADB folder WARNING: -> Unlocking bootloader will erase all your data. So backup your data before unlocking bootloader PROCEDURE : -> keep mobile Turn off and connect mobile to PC using USB cable -> Now at the top you can see RED led glowing. Once you observe it keep pressing the Volume up rocker button and your device will move to fastboot mode. -> Now navigate to ADB folder c:/ADB -> Now open adb terminal by "shift + right click" and select "open command prompt here" Now follow these steps in adb terminal: Code: fastboot -i 0x1ebf oem unlock NOTE: If U are facing issue like "waiting for device" when U type the command then please follow METHOD 2 Code: fastboot -i 0x1ebf flash recovery recovery_yuphilz.img [OR] Code: fastboot -i 0x1ebf boot recovery_yuphilz.img Note : if you download any other custom recovery which is named differently just replace "recovery_yuphilz.img" to ur recovery name "your_recovery.img" without quotes in above command. Code: fastboot -i 0x1ebf reboot that's it now your bootloader as been unlocked and installed philz custom recovery NOTE: In this stage i suggest you take full nandroid backup which is very very very useful in future and dont delete that backup ever. i always suggest philz which works on both touch interface as well as device hard keys. TO ROOT YOUR DEVICE -> Place "UPDATE-SuperSU-v2.45.zip" in your internal or external Sd card -> reboot to recovery and select install zip from storage and browse to the folder where you have downloaded the superuser.zip that's it now your device has been rooted For those who are facing Device Detection issue on adb METHOD - 2 (USING PDANET SOFTWARE) . Requirements : Laptop or Desktop with windows OS USB Data cable Files Required: ADB.zip : DOWNLOAD HERE Philz Recovery : DOWNLOAD HERE SuperSU : DOWNLOAD HERE PdaNet mobile app : DOWNLOAD HERE PdaNet PC application : DOWNLOAD HERE Download ADB zip file and extract it in your PC path C:/ADB now place philz recovery : "recovery_yuphilz.img" in that folder WARNING: -> Unlocking bootloader will erase all your data. So backup your data before unlocking bootloader PROCEDURE : -> Download and install PdaNet mobile app : https://play.google.com/store/apps/d...?id=com.pdanet -> enable usb debugging in setting -> Developer options -> Mark ADB debugging and USB debugging -> Install PdaNet software in PC : Download PdaNet+ -> when PdaNet software in PC requested to connect mobile Keep mobile TURN ON and connect it using USB cable. -> it will install the device drivers automatically, if already installed select reinstall option -> Now unplug the device from USB cable -> Now reboot PC as well as mobile -> now keep mobile TURN ON and connect mobile to PC using USB cable -> Now navigate to ADB folder c:/ADB -> Now open adb terminal by "shift + right click" and select "open command prompt here" Now follow these steps in adb terminal: Code: adb devices Code: adb reboot-bootloader Code: fastboot -i 0x1ebf oem unlock Code: fastboot -i 0x1ebf flash recovery recovery_yuphilz.img [OR] Code: fastboot -i 0x1ebf boot recovery_yuphilz.img Note : if you download any other custom recovery which is named differently just replace "recovery_yuphilz.img" to ur recovery name "your_recovery.img" without quotes in above command. Code: fastboot -i 0x1ebf reboot that's it now your bootloader as been unlocked and installed philz custom recovery NOTE: In this stage i suggest you take full nandroid backup which is very very very useful in future and dont delete that backup ever. i always suggest philz because which works on both touch interface as well as device hard keys TO ROOT YOUR DEVICE -> Place "UPDATE-SuperSU-v2.45.zip" in your internal or external Sd card ->reboot to recovery and select install zip from storage and browse to the folder where you have downloaded the superuser.zip that's it now your device has been rooted THANX Bro here is your file click and download here one click download link if you like my post just press onlybutton _________________ B.R Abhay_Rana_Singh!!!! Source Last edited by ~Leo~; 12-15-2015 at 17:41. |
The Following 10 Users Say Thank You to abhayranasingh For This Useful Post: |
08-27-2015, 03:00 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | This is too bad , at least you should mention the source link where you copy it Original source - [TUT][Normal and PDANET Method] YUREKA-UNLOA… | YU Yureka | XDA Forums Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
08-28-2015, 12:50 | #3 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Today i have flashed by fastboot method after flash mobile becomes dead not making any port only shows red light if i insert usb cable without battery |
09-22-2015, 07:25 | #7 (permalink) |
Member: 2388887 Status: Offline Sonork: 100.1623070 QQ 3208774531 Thanks Meter: 1,203 | Flashing Procedure And Flash File By Me Working Link Yureka Micromax YUREKA Flash File And Flashing Procedure In Video BY Me All Problem Solved Flash Yureka With This Flashing Procedure Download : Flash File : Yureka Latest Version Flash File 4.4.035.00.P1.150420.8675_I01_ROM.rar Flashing Procedure Video 100% tested By Me : Yureka AO5510 Flashing Procedure Video 100% tested By Me Plz Read This Rules Use Thanks Button instead _________________ B.R Abhay_Rana |
The Following User Says Thank You to abhayranasingh For This Useful Post: |
12-24-2016, 10:33 | #15 (permalink) |
Junior Member Join Date: Dec 2010 Location: berhampur Age: 34
Member: 1475961 Status: Offline Thanks Meter: 4 | yu5510 bootloader unlock successsful yu5510 bootloader unlock successsful by tow commands adb devices fastboot -i 0x1ebf oem unlock fastboot -i 0x1ebf reboot |
The Following 2 Users Say Thank You to santosh92 For This Useful Post: |
