Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 12-26-2015, 09:53   #1 (permalink)
mediapeople's Avatar
Member: 759477
Sonork: 100.1618763
Thanks Meter: 111
Yureka yu5010a frp lock
Yu 5010a how to remove frp lock
Old 01-05-2016, 10:23   #2 (permalink)
Member: 1910376
Thanks Meter: 50
http://forum.gsmhosting.com/vbb/f25/...u5010-2033054/
The Following User Says Thank You to khothbharat For This Useful Post:
Old 07-22-2016, 15:25   #3 (permalink)
Member: 1232324
YU 5010a
Thanks bro..
this is useful post for remove frp
Old 07-26-2016, 15:25   #4 (permalink)
Member: 2508657
Sonork: 100.1623070
Thanks Meter: 380
How to Reset Google ID in Lollipop Handset (YU5010A & YU5010)
There Is A Solution arrived To reset The Google Id Issue In
Yuphoria (YU510A & YU5010 ) After Flashing lolipop Software
Pls Follow below Step to do the reset,the same i have tested and
its working find..
1. Keep the ADB file in desktop ( The same file is used to solve
the boot mode issues in A109 , A310 , A311 )
2. Press and hold Vol + key and then connect the handset.
3. Handset will enter in to boot mode
4. Once entered, release the Vol + key.
5. Now run below commands in CMD window
cd desktop\adb
Adb devices
Fastboot -i 0x2a96 erase config
Fastboot -i 0x2a96 reboot
6.After executing this command the handset will reboot automatically…
7. Now the handset will not ask for google ID when boot up.
Pls Note that the same procedure can be tried out in all lolipop OS Handset Should Be in Boot Mode.
Note-To make the handset to boot mode “usb debugging” to Be enabled
The Following 5 Users Say Thank You to .::Advance::. For This Useful Post:
Old 08-14-2016, 16:34   #5 (permalink)
rajasekar's Avatar
Member: 503989
Thanks Meter: 71
Frp lock remove Tools Micromax All In One · HOME | Download Firmware File
Old 08-30-2017, 05:54   #6 (permalink)
Member: 2176571
Thanks Meter: 4
.................superb......
Page generated in 0.16014 seconds with 9 queries
