Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News
iPhone, iPad, iPod - FAQ, Guide, How To, Tutorials , News iPhone, iPad, iPod Jail break, Activation and Unlocking Step by Step How-To: Help, Guides , Tutorials and News
Old 12-06-2019, 16:34   #46 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 144
Any one can sort out after jailbreak network full 3G/4G ok but no calls i tried to replace the 3 files but still cant make a call or use data services any solution ................
Old 12-06-2019, 18:38   #47 (permalink)
Member: 969318
Thanks Meter: 82
Originally Posted by loca|host View Post
easiest way is installing WineHQ and using WinSCP .
How to login iphone 6 with winscp?
Old 12-06-2019, 18:53   #48 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
Open Terminal and run this cmd : iproxy 2222 44
Then open WinSCP and use this config to SSH :
File Protocol : SCP
Hostname : localhost
Port number : 2222
User name : root
Password : alpine
To be able to access your iDevice in Read/Write mode , launch this cmd in WinSCP Terminal : mount -o rw,union,update /
__________________
Regards,
Mehdi
The Following 2 Users Say Thank You to loca|host For This Useful Post:
Old 12-06-2019, 19:08   #49 (permalink)
Member: 969318
Thanks Meter: 82
How to get network and make calls after bypassing icloud?
Old 12-06-2019, 19:31   #50 (permalink)
Member: 969318
Thanks Meter: 82
Also, can i first copy from activated phone and copy to other phone using winscp these files?
/var/root/library/lockdown/data_ark.plist
/var/containers/data/system/com.apple.mobileactivationd/library/internal/data_ark.plist
/var/containers/data/system/com.apple.mobileactivationd/library/activation_records/activation_record.plist
Old 12-08-2019, 21:53   #51 (permalink)
Member: 505752
Sonork: 1611502:zubair
Thanks Meter: 33
must reply me
if i copy these 3 files in my bypass device can possible to use call making and all others options which will blocked in simply bypass ..
plz guide us and tell us how to copy these file in my phone ??
Old 12-09-2019, 00:59   #52 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
Originally Posted by chand_gee View Post
I m using this tool...for bypas icloud
Click on usb then icloud to trash and done
No need to enter commands just one click done.
https://mega.nz/#!wg1ThIAa!-UCpRQkOj...gd0Btq2xN4zUe0
Sent from my iPhone using Tapatalk Pro
i am bad on cmd please link again
Old 12-09-2019, 11:30   #53 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
link don't work; it's possible to re-upload? thanks
Old 12-09-2019, 14:49   #54 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
https://drive.google.com/file/d/1ieD...ew?usp=sharing
The Following 2 Users Say Thank You to chand_gee For This Useful Post:
Old 12-11-2019, 02:25   #55 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
File Protocol : SCP
Port number : 2222
User name : root
Password : alpine
can i use this on win after Jb on mac?
Old 12-12-2019, 18:53   #56 (permalink)
Member: 969318
Thanks Meter: 82
I’m as clueless as you bro, seems like there are a lot of bugs after bypass
Old 12-14-2019, 15:47   #57 (permalink)
Member: 2111064
Thanks Meter: 21
can u confirm whether calling works after jailbreak or bypass icloud? and the link you mentioned earlier for installing high siera, will check ra1n work after installation?
pls reply bro
wbr
Old 12-14-2019, 15:50   #58 (permalink)
Member: 2111064
Thanks Meter: 21
pls give new link as old link not working
wbr
Old 12-16-2019, 19:22   #59 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
pls reply bro
wbr
As i check problem not solved in my case, iphone7 plus
Bypass icloud,
Signal are fine LTE
USSD Cammands are working fine but data end call not work.
Old 12-17-2019, 04:58   #60 (permalink)
Member: 792851
Thanks Meter: 136
Link u gave its not working cna u share another link plz
Page generated in 0.25600 seconds with 8 queries
